Which valve springs and bearings? - Team Camaro Tech
post #1 of 2 (permalink) Old Mar 4th, 10, 10:45 AM Thread Starter
Jakob
Hi guys and gals. I am now asking for your help again
After finding out that somehow a couple of the valve springs in the heads have snapped (which explains the ticking noise coming from the engine now and then), I contacted Crane Cams to order a set of springs which are recommended for the installed camshaft. Unfortunately, Crane Cams have these backordered for 60-90 days! With the season starting here in DK very soon, I can definately not wait this long.
I have tried to find valve springs from other manufacturers, but I havn't been able to find a set springs with the exact specs. So what shall I do? Shall I find a set of springs with specs that are close enough? What about the various specs such as spring rate, seat pressure etc. Shall I go abit higher or lower?
Links to techsheets:
Springs: http://cranecams.com/index.php?show=...&lvl=3&prt=123
Cam: http://cranecams.com/?show=browsePar...tNumber=138601
And another thing. I am also going to need some new bearings (main, rod and cam) and piston rings for my 427 with a steel crank, TRW 0.30 pistons, and 3873858 heads (street engine, though with a heavy foot, with the occasional track day). Which brand/series would you recommend?
Any help will be greatly appreciated
PS. If you know of a good speedshop with low shipping costs to Europe, please give me a shout
'69 Camaro SS X22 - finally arrived
Pics and details coming soon
klartder is offline
post #2 of 2 (permalink) Old Mar 4th, 10, 11:27 AM
Re: Which valve springs and bearings?
Might try looking at Comp or Cam Motion to match up what you have. You could even cut spring pockets and go with a larger spring that may last you longer. Just match up spring pressures according to cam card.
King or TRW bearings would work.
TC # 349
zdld17 is offline
