camshft opinion - Team Camaro Tech
post #1 of 4 (permalink) Old Mar 5th, 10, 07:26 PM Thread Starter
Kelly
camshft opinion
I need some input on what cam to get and i m hoping that i can get some ideas here. The engine is a 454, oval port heads, performer intake, I don't know the compression. trans is a 4spd, also i am not sure what gear it has, but i am changing that anyway. What i want is something that sounds a little lumpy and makes good power. The car gets driven around town and some freeway driving. I am looking to get opinions on what you guy's have used and how you liked it. Thanks for the input.
butternut1972 is offline
post #2 of 4 (permalink) Old Mar 6th, 10, 05:43 PM
dondb's Avatar
Re: camshft opinion
You need to give more info then you gave for advice.......what gear are you going to put in,heads,intake and you really need to find the compression ratio. Then you'll get more info then you can digest...there are some very experienced people on this forum
69 X-44 Camaro, slowly upgrading to my liking...Hmmm, i guess i'll never be done
2002 Camaro LE SS...Many upgrades
1969 Step Side LWB C10
dondb is offline
post #3 of 4 (permalink) Old Mar 6th, 10, 06:04 PM
george
Re: camshft opinion
Kelly..any clue as to what this 454 came out of?Do you know its history?
Casting #,s off the block and heads might help us determine the static cr if she is still oem specced.If its been apart in the past..then all bets are off.Could be .030" to .0100" overbore with god only knows what rebuilder piston.Muster up all you know..more is better and post back.
George
68 Camaro
8-71 blown 461 Rat on E-85
fatblock is offline
post #4 of 4 (permalink) Old Mar 6th, 10, 08:34 PM Thread Starter
Kelly
Re: camshft opinion
Thanks guy's. I found a few other problems with the motor today so i am going to rebuild it. I got a little ahead of myself there, and I should of checked some other things first. I apprciate the response.
