i cant turn the harmonic balancer?? for TDC - Team Camaro Tech
post #1 of 10 (permalink) Old Mar 5th, 10, 09:26 PM Thread Starter
i have a350 , im trying to get my engine to TDC. i was trying to turn the crank by the harmonic balancer to feel the the #1 cylinder. But i cant turn it. all the spark plug wires are removed and there is no distributo in there. Any suggestions?
brianstevens03 is offline
post #2 of 10 (permalink) Old Mar 5th, 10, 09:28 PM
Steiner
Re: i cant turn the harmonic balancer?? for TDC
Manual transmission? Is it in neutral?
'69 Camaro
500hp/538lbft
Steiner is offline
post #3 of 10 (permalink) Old Mar 5th, 10, 09:30 PM
Michael Gekko
Brian,
Make sure the spark plugs are removed.
Eleanor's Nemesis is offline
post #4 of 10 (permalink) Old Mar 5th, 10, 09:31 PM
Try removing the spark plugs too, not just the wires.
BPOS is offline
post #5 of 10 (permalink) Old Mar 5th, 10, 10:00 PM Thread Starter
didnt mean to say wires. the spark plugs are removed. I will check about it being in nuetral. I dont believe it is.
post #6 of 10 (permalink) Old Mar 5th, 10, 10:06 PM
Shawn
thats why the engine isnt turning, assuming you have a manual
victimizati0n is offline
post #7 of 10 (permalink) Old Mar 5th, 10, 10:24 PM
Steiner
And don't forget to keep your thumb over the #1 hole when you're trying to find TDC. The damper mark will line up at TDC for both #6 and #1. It will only build pressure on the #1 cylinder when coming around on TDC for #1 though.
'69 Camaro
500hp/538lbft
Steiner is offline
post #8 of 10 (permalink) Old Mar 5th, 10, 11:03 PM Thread Starter
thanks everyone. It is a manual. Will do.
post #9 of 10 (permalink) Old Mar 6th, 10, 08:38 AM
Have you tried turning it both directions?
deerhunter is offline
post #10 of 10 (permalink) Old Mar 6th, 10, 08:22 PM
Ron
Don't use the Damper Bolt and turn the Engine Counter Clock Wise with the Plugs in or In Gear because you will loosen it and have to take the Starter off to jam the Flywheel in order to Re-Torque it.
The engine should turn over with approx 25ft/lbs of pressure maybe more depending on Valve Spring Pressures. If it don't you got a Rub in there or possible seized from sitting around, in which case you will have to lube the Rings with Kerosene or Rust Check and let her sit while.
This was my 70 1/2 Z28
Z15CAM is offline
