Goint to change oil today - Team Camaro Tech
post #1 of 6 (permalink) Old Mar 6th, 10, 08:37 AM Thread Starter
My car has been sitting since the winter came in. I am going to change the oil today to prepare for spring. Should I warm the car up before changing the oil or change it cold?
1969 Camaro SS
350/300 M20
12 Bolt 3:73 Posi
Myfirst 69SS is offline
post #2 of 6 (permalink) Old Mar 6th, 10, 08:39 AM
Re: Goint to change oil today
I would warm it up good so any contaminents get suspended in the oil.
deerhunter is offline
post #3 of 6 (permalink) Old Mar 6th, 10, 09:00 AM
Andrew
Andrew69's Avatar
Should you first take it for a 15 to 20 minute drive to suspend all the contaminants and burn off any moisture in the crankcase?
Skunk Works
Some photos:
Member # 159
Andrew69 is online now
post #4 of 6 (permalink) Old Mar 6th, 10, 04:43 PM
Rich
The hotter the better ALWAYS! Even on my work truck I drive it 30 miles to work and then drop the oil as soon as I get there.
RichSchmidt is offline
post #5 of 6 (permalink) Old Mar 6th, 10, 08:21 PM
DT
Donny
DT's Avatar
Never change oil COLD!!!
DT is offline
post #6 of 6 (permalink) Old Mar 8th, 10, 08:35 AM
JohnZ's Avatar
A better plan for next year is to change it (hot) a day or so before you put it up for the winter, so all the oil is fresh and clean during its winter "sleep", with no blow-by contaminants, condensate moisture, etc.
JohnZ
CRG
JohnZ is offline
