82 350 - Team Camaro Tech
post #1 of 7 (permalink) Old Mar 6th, 10, 01:20 PM Thread Starter
corey
82 350
hey just a quick question ,when you are setting your air /fuel mixture wit a vaccume gauge were can you plug it in if all the manifold vaccume ports are blocked off . I just have the vaccume on the carb . Its a holly 670 cfm on a edlebrock performer intake
steps350 is offline
post #2 of 7 (permalink) Old Mar 6th, 10, 02:32 PM Thread Starter
corey
Re: 82 350
anyone?
steps350 is offline
post #3 of 7 (permalink) Old Mar 6th, 10, 04:05 PM
Re: 82 350
Put in or use a "T" in the line, and cap it when you are done.
TJS69 is offline
post #4 of 7 (permalink) Old Mar 6th, 10, 04:49 PM Thread Starter
corey
Re: 82 350
put it were? sorry
steps350 is offline
post #5 of 7 (permalink) Old Mar 6th, 10, 09:27 PM
Smile Re: 82 350
You should have manifold vacuum some where. Just unhook a vacuum hose (with the car running) and see if it is sucking. If it is cut the line and put a "T" fitting. Make sure your vacuum is from a source that always has vacuum.
TJS69 is offline
post #6 of 7 (permalink) Old Mar 7th, 10, 07:54 PM
JohnZ's Avatar
Re: 82 350
Most Holleys have a full manifold vacuum source nipple on the pass. side of the front of the baseplate, at an angle - usually has a rubber hose on it to the choke pull-off diaphragm. Tee into that hose.
JohnZ
CRG
JohnZ is offline
post #7 of 7 (permalink) Old Mar 7th, 10, 11:59 PM Thread Starter
corey
Re: 82 350
ok thanks for the info I saw the one you are talking about , I will tee into that one
steps350 is offline
