Fuel Lines - Team Camaro Tech
post #1 of 9 (permalink) Old Mar 7th, 10, 08:09 AM Thread Starter
Greg
Fuel Lines
Still redoing my 69 small block 350, I put in a new Gas Tank, Fuel Line and Fuel Pump. Need advice. Is there any priming that needs to be done or filling the lines with gas or anything I need to do before I try to start it ?
69-454 is offline
post #2 of 9 (permalink) Old Mar 7th, 10, 08:16 AM
Kevin
Re: Fuel Lines
I'm not sure about primimg the pump...my dad never did, we always took a mason jar full of gas and poured it into the carb for a few minutes until the pump had time to pull fuel up. oh yeah and we always had glass housed fuel filter so we could see when the fuel got there (p.s. pray for no backfire)
rs69conv is offline
post #3 of 9 (permalink) Old Mar 7th, 10, 08:26 AM
Re: Fuel Lines
Usually just cranking will fill the line/pump. As above, just prime the carb and things will go quicker
68 Camaro~LSx ~all motor
post #4 of 9 (permalink) Old Mar 7th, 10, 09:11 AM
Re: Fuel Lines
If mech pump, you can disconnect the inlet line at the pump and pour some fuel into the tank, say 5 gals or so, and pressurize the tank with shop air and a rag at the fuel cap/inlet and stop when fuel comes out or continue to remove installation debris.
If electric pump, same thing, disconnect the inlet to the regulator and either or turn on the pump to self prime and/or pressurize the tank to prime the pump and let it pump to remove debris.
Save the gas for your lawn mower.
post #5 of 9 (permalink) Old Mar 7th, 10, 09:49 AM
Dave M
Barefoot Dave's Avatar
Re: Fuel Lines
This is exactly how I do it. Doesn't take much pressure and works like a dream. If it's a new motor you'll wanna make sure the the carb bowl (s) have gas in them so it will fire right away. One of the worst things for a new engine is prolonged cranking without firing.
Pouring raw gas into the carb is bad in SO many ways. Fire hazard for one and it washes the oil off of the cylinder walls just when you want the rings to get the full effect of the nice cross hatch honing that you just paid for.
Dave Miller
Barefoot Dave is offline
post #6 of 9 (permalink) Old Mar 7th, 10, 04:48 PM Thread Starter
Greg
Re: Fuel Lines
Thank You, That is what I needed to know.
69-454 is offline
post #7 of 9 (permalink) Old Mar 7th, 10, 04:55 PM
Re: Fuel Lines
Maybe should have been more specific ?
Fill the carb bowls through the vent tube....don't just pour down the venturi.
post #8 of 9 (permalink) Old Mar 7th, 10, 04:59 PM
Dave M
Re: Fuel Lines
GREAT point Doug! It's easy on a Holley but takes some thinking on a quadrajet. Hopefully he gets it right.
Dave Miller
post #9 of 9 (permalink) Old Mar 10th, 10, 12:07 PM Thread Starter
Greg
Re: Fuel Lines
Got it.. Thanks
69-454 is offline
