Who's using Vortec heads on their 1st gen with headers ? - Team Camaro Tech
post #1 of 12 (permalink) Old Mar 7th, 10, 02:04 PM Thread Starter
seeburg220's Avatar
I have a '69 with a 350 that's using Vortec heads. I bought Dougs D368 headers for it and they don't fit. The #5 spark plug boot is getting burned up because it's touching the pipe. I tried denting the header some, but to no avail. Also the #6 pipe comes in contact with the idler arm. I dented that too. These clearly do not fit, and I'm wondering if someone can recommend a brand and model header that WILL fit a vortec-headed small block. Thanks.
1969 / 350 / TH350 / 3.73 posi / driver
seeburg220 is offline
post #2 of 12 (permalink) Old Mar 7th, 10, 03:37 PM
67 Camaros Rock
Joe Harrison's Avatar
Re: Who's using Vortec heads on their 1st gen with headers ?
I have had these elcheapo headers from summit for years and I don't have an issue. I run a 90 degree boot and don't have any issues.
-Mark Donahue
My 67 Camaro Time Line
Joe Harrison is offline
post #3 of 12 (permalink) Old Mar 7th, 10, 03:50 PM
The reason the idler arm is hitting is likely because it's an aftermarket part house idler. Search "D368" on this site - I'm pretty sure this has come up before, and a part# for an idler that won't hit is available.
On the #5 plug, have you tried a "shorty" plug with a 90 degree boot? I believe Accel makes shorty plugs.
If these two fixes will gwt your headers to clear it save you a bunch of money.
BPOS is offline
post #4 of 12 (permalink) Old Mar 7th, 10, 05:28 PM
JAY
I do run Accel shorty plugs in mine/ 350 GM crate motor with
vortex heads/Hooker shorty headers. Most likely if you go to shorty plugs your problem will be solved. See pictures !
66 SS Chevyll
67 Elcamino
68 Malibu 2dr
69 Camaro Convertible
JAYARTER is offline
post #5 of 12 (permalink) Old Mar 7th, 10, 07:37 PM
I am having a similar issue with the Vortec heads on my 383. Even with a 90 degree boot I keep burning up number 6 with my hooker headers. I am currently using the AC Delco R44LTS. What is the part number for the Accel shorty plugs?
737IP is offline
post #6 of 12 (permalink) Old Mar 7th, 10, 08:46 PM
My vortec heads have angled plugs. I have no problems with the wires. I'm using the red GMPP plug wires with the GMPP wire hangers. They are pricey but fit very well.
These are the ones shown in the GMPP catalog on most the the crate motor pics.
Known to run with scissors....
__________
1969 Camaro Z/28 "clone", GMPP ZZ383, Autogear M22W, Moser 12bolt w/TruTrac 3:73.
Fred Mertz is offline
post #7 of 12 (permalink) Old Mar 9th, 10, 07:59 AM Thread Starter
seeburg220's Avatar
Thanks Guys for the help ! I will try the shorty plug. As far as the idler arm, I know about the aftemarket/oem size thing. I have the smaller arm from Rick's, but I still had to dent the header to get a 1/4" clearance. Will post my progress on this.
post #8 of 12 (permalink) Old Mar 9th, 10, 08:01 AM Thread Starter
seeburg220's Avatar
Mine are straight-plug heads, stock GM Vortecs. Wish I would have known they made an angled-head !
post #9 of 12 (permalink) Old Mar 9th, 10, 09:29 PM
The angle plug head is the stock head on the ZZ383.
__________
post #10 of 12 (permalink) Old Mar 10th, 10, 05:47 AM
I run 90 degree boots with hedaman 1 5/8 headers on stock vortec headed 350/330 ho motor and they fit fine.
Dave69Z is offline
post #11 of 12 (permalink) Old Mar 12th, 10, 08:37 AM Thread Starter
seeburg220's Avatar
Well, I tried the shorty plugs, and it's still not enough to fix it. Looks like I have to raise the car off of the ground 2 feet and drop the header out and dent the crap out of it to clear the #5 plug...Ugh.....Or throw away a $600 pair of headers and start over.
post #12 of 12 (permalink) Old Mar 12th, 10, 05:17 PM
JASON
I'm running Hedman elite shorty headers on my 68 they fit fine on my 327 and with my new 350 with vortec head with no issues.
JASON2478 is offline
