Brown oil - Team Camaro Tech
post #1 of 12 (permalink) Old Mar 7th, 10, 10:24 PM Thread Starter
sean
Brown oil
I have my 400sb out cleaning it up and replacing oil pan and found some brown and white oil. I figure its a water leak somewhere. Was thinking of replacing head gaskets. I have been using Quaker state 5w30 lately and was reading about some complaints with the oil turning brown prematurely. Do you think the head gasket is a good next step?
sean69cam is offline
post #2 of 12 (permalink) Old Mar 8th, 10, 04:47 AM
Re: brown oil
Pressurize the coolant system and see if the pressure drops.
Where you adding coolant to the system?
I'd use a different brand of oil and weight, 10W30, and view the results.
post #3 of 12 (permalink) Old Mar 8th, 10, 09:58 AM
Dan Ensign
Re: Brown oil
The white is from condensation, I would consider this normal.
Dan E.
69 SS396 4spd. 4.10 posi. x66 coupe
Dan E. is offline
post #4 of 12 (permalink) Old Mar 8th, 10, 04:11 PM Thread Starter
sean
Re: Brown oil
The engine has been sitting in the garage for about 3 months while rebuilding the car. Oil in valve covers looked good. Just noticed the brown oil in the oil filter and oil pan
post #5 of 12 (permalink) Old Mar 8th, 10, 06:03 PM
Bill
Re: Brown oil
Sean,
That sounds like condensation to me too. If the majority of the oil was ok, then I would not worry about it too much.
Bill Koustenis
Owner
Advanced Automotive Machine
Waldorf Md
BillK is offline
post #6 of 12 (permalink) Old Mar 8th, 10, 06:39 PM
Re: Brown oil
A little bit by itself is probably condensation - if you drain the oil and it's all muddy looking you are getting water in the oil from somewhere.
69 Pace Car and 69 Hard top
srode is offline
post #7 of 12 (permalink) Old Mar 8th, 10, 07:34 PM Thread Starter
sean
Re: Brown oil
the oil looks muddy
post #8 of 12 (permalink) Old Mar 9th, 10, 12:41 AM
AJ
Re: Brown oil
You can do a leak test with this dye and look for it with a black light or uv light, I forgot which it is.
When I pulled my pan, there was some muddy oil and metal in the pan, normal, and runs and drives fine.
Every time you started the motor, did you let it get to running temp?
Did you ever start it in the garage for the heck of it, let it idle for a bit and then shut it off? This will cause sludge, and condensation in the pan and pan rails.
Also, when I used to run lucas oil, my pan looked even worse, my take on additives is don't use them.
'68 333" Camaro
'14 5.0 Mustang
ace's68 is offline
post #9 of 12 (permalink) Old Mar 9th, 10, 01:55 AM
Steiner
Re: Brown oil
Check out the easy stuff first. Pull the valve covers and see if there is evidence of coolant around any of the head bolt heads or rocker studs. They need to have sealant on them.
'69 Camaro
500hp/538lbft
Steiner is offline
post #10 of 12 (permalink) Old Mar 10th, 10, 02:25 PM
Wes
Re: Brown oil
Muddy color is rust. Has the engine been sitting?
White color could be a coolant leak, but also could be simple condensation as stated above. Does your operating (coolant) temp get high enough so that the oil gets to 212 degrees (boiling point of water)? Is your PCV system operational? Once the oil temp is 212F, liquid water is vaporized from the oil then this vapor is removed from your crankcase via your PCV system.
Typically, a coolant temp of 180-190 F will equate to an oil temp of 210-220.
Straight-line-69 is offline
post #11 of 12 (permalink) Old Mar 10th, 10, 02:35 PM Thread Starter
sean
Re: Brown oil
I had trouble with low oil pressure, so I really didn't get the engine up to operating temps. Come to find my oil pickup was clogged with the black silicone. The engine has been sitting for about three months, so rust could be a possibility. I decided last night to just go ahead and pull heads. Everything looked great, gasket was fine. So far no problem detected, removing heads wasn't neccesary.
post #12 of 12 (permalink) Old Mar 10th, 10, 02:38 PM
Fred
Re: Brown oil
Yep, never let your engine run for longer than a few seconds unless you let it warm all the way and then some. After 41 years my car has never had anything but bare metal showing where the oil resides.
128.79mph 1.428 60'
Fred Ficarra is offline
