Distributor questions for JohnZ. - Team Camaro Tech
post #1 of 3 (permalink) Old Mar 8th, 10, 08:15 AM Thread Starter
Gary
69Z28's Avatar
Hi John. I was reading an older post on the distributor grease well and you stated using strips of gauze packed in the well and saturated with 30W.
Is this still acceptable? How big are the strips of gauze?
06A 1969 Camaro Z28 X33D80 69 B 711 Black Stripes Console w/tach and gauges.
69Z28 is offline
post #2 of 3 (permalink) Old Mar 8th, 10, 08:23 AM
JohnZ's Avatar
Re: Distributor questions for JohnZ.
I just cut up typical gauze bandages (doesn't matter what size they are to start with), pack them into the well until it's full, then add motor oil to saturate them, and install the plastic seal. Learned this years ago from Dave Fiedler, the "guru" of Corvette distributors (www.tispecialty.com).
Delco used to have a "Gear and Shaft Lubricant" for that purpose, but it was discontinued years ago (plastic tub in photo below, with tube of distributor cam lube).
JohnZ
CRG
JohnZ is offline
post #3 of 3 (permalink) Old Mar 9th, 10, 03:18 PM Thread Starter
Gary
69Z28's Avatar
Thanks for the info and the article link.
According to the the article the gauze should be 3" x 3" square. Is this better or one continues strip 1/4" x 20 feet, or inches or little chip cuts?
Just want to get this right the first time.
69Z28 is offline
