Intake gasket heat riser block off failure - Team Camaro Tech
post #1 of 15 (permalink) Old Mar 9th, 10, 05:28 PM Thread Starter
Jerry R.
jr68's Avatar
I made some home made heat riser block offs out of .010 stainless sheet.
They have been in around 4 years and yesterday when I took the intake off I noticed they both were ate right thru. More like burned thru. My question is what do you guys use to block off the heat riser passage ? I think there is a gasket with a block off but I haven't had any luck finding one yet.
I have a 327 with original iron heads.
my Magnaflow X-pipe system sound clip, click the link
jr68 is offline
post #2 of 15 (permalink) Old Mar 9th, 10, 05:33 PM
Re: Intake gasket heat riser block off failure
Do you have a heat riser??
john68 is offline
post #3 of 15 (permalink) Old Mar 9th, 10, 05:56 PM
The problem is the localized heat on the sheet(s); nothing is behind the sheet to dissipate the heat.
The best solution is to install a manifold with no crossover, the heat is spread about the manifold.
You could machine pockets into the manifold to 'fit' steel sheets (A36) and then clamp on the manifold onto the heads.
post #4 of 15 (permalink) Old Mar 10th, 10, 11:20 AM Thread Starter
Jerry R.
jr68's Avatar
John, more like a crossover like Everett said.
Thats a better word.
jr68 is offline
post #5 of 15 (permalink) Old Mar 10th, 10, 11:31 AM
No I am talking about a heat riser on the rt exhaust pipe, just below the manifold,
it is to send extra heat thru the crossover, to help warm up the intake, and help the divorced choke.
john68 is offline
post #6 of 15 (permalink) Old Mar 10th, 10, 05:44 PM
His pictures shows the car has headers installed, at least the ones I seen.
post #7 of 15 (permalink) Old Mar 10th, 10, 05:49 PM
I didn't go to the trouble of lookin at picts in another place, sorry my fault I didn't do all the background info.
john68 is offline
post #8 of 15 (permalink) Old Mar 10th, 10, 05:50 PM Thread Starter
Jerry R.
jr68's Avatar
Yup , headers
jr68 is offline
post #9 of 15 (permalink) Old Mar 10th, 10, 06:47 PM
"Tri-Tip"
Gary L's Avatar
Does it really need to be blocked if you have headers? Will the plenum stay cooler somehow? To what extent?
Gary L is offline
post #10 of 15 (permalink) Old Mar 10th, 10, 09:06 PM Thread Starter
Jerry R.
jr68's Avatar
The exhaust port in the head actually has an exit to the intake manifold and it crosses over to the other side so it can speed warm up.
I dont drive her in cold weather so I just as soon keep that heat out of there and keep the carb cooler.
jr68 is offline
post #11 of 15 (permalink) Old Mar 12th, 10, 08:04 PM Thread Starter
Jerry R.
jr68's Avatar
How about if I have a pro weld in a 1/4 " aluminum plate in that port and recess it a bit so it doesn't touch the head.
jr68 is offline
post #12 of 15 (permalink) Old Mar 12th, 10, 08:24 PM
Bill
Jerry,
Exhaust gas is pretty corrosive, especially if the engine is run on short trips most of the time. Back in the 70's we used to cut a pc out of a beer can and use it and never had any issues, but it was pretty rare for a manifold to stay on for 4 years without having it off to mess with something I would not worry about it too much, put in a new block off and call it a day.
Bill Koustenis
Owner
Advanced Automotive Machine
Waldorf Md
BillK is offline
post #13 of 15 (permalink) Old Mar 12th, 10, 08:53 PM Thread Starter
Jerry R.
jr68's Avatar
Bill I had .010 stainless shim stock in there and both got ate up in 4 years.
Someone must make a gasket with block offs already in them.
I'd be ok with just sticking them in .
jr68 is offline
post #14 of 15 (permalink) Old Mar 17th, 10, 09:02 PM Thread Starter
Jerry R.
jr68's Avatar
Who sells a good gasket with block off ?
jr68 is offline
post #15 of 15 (permalink) Old Mar 18th, 10, 04:28 AM
Fel-Pro has them.
