Cylinder head question - Team Camaro Tech
post #1 of 3 (permalink) Old Mar 9th, 10, 06:01 PM Thread Starter
Chad
Just got a used 396 engine and all exh. passages on the heads are carboned up and fairly black but 1 cylinder is not so much but has some surface rust. Should this be a concern ? Previos owwner said he knew of no problem and seemed honest. Oil is clean but dark and there was still coolant in the engine and he said he never topped off or saw smoke. Am I just paranoid ?
chadscamaro is offline
post #2 of 3 (permalink) Old Mar 9th, 10, 06:07 PM
Bri
bwcamaro68's Avatar
Re: Cylinder head question
could of been very rich in the jets setting of the carb, you wouldnt tell unless you smelled it most times.
just my 2 cents....
"Three Rules of Work: Out of clutter find simplicity; From discord find harmony; In the middle of difficulty lies opportunity."
Albert Einstein
"Never Forget" FDNY 9/11/01
I have more than 4 Camaro's am I Addicted?
bwcamaro68 is offline
post #3 of 3 (permalink) Old Mar 9th, 10, 07:23 PM Thread Starter
Chad
Its an efi setup if that helps ?
