Need help with engine idle? - Team Camaro Tech
post #1 of 15 (permalink) Old Mar 10th, 10, 06:26 PM Thread Starter
383 SB with TH350 and 2400 stall. In drive it idles @ 850 rpm, any lower and it dies. But in park it idles at about 1250 rpm and seems high to me? Is this normal, if not what could cause it? The car drives great otherwise just wondering about the idle? Thanks
1969 Camaro SS
Black Z is offline
post #2 of 15 (permalink) Old Mar 10th, 10, 06:30 PM
Re: Need help with engine idle?
What carb are you running,and also what is the timing set at,is the carb 4 corner idle ?
67 RS 355sbc 11.76et @ 116mph 1.67 60' Deluxe Parchment interior
Bad67355 is offline
post #3 of 15 (permalink) Old Mar 10th, 10, 06:33 PM Thread Starter
Holley 770 street avenger vacuum secondaries, 13 initial, 34 total all in by 3000 rpm.
1969 Camaro SS
Black Z is offline
post #4 of 15 (permalink) Old Mar 10th, 10, 06:35 PM
AJ
Are you running vacuum advance?
'68 333" Camaro
'14 5.0 Mustang
ace's68 is offline
post #5 of 15 (permalink) Old Mar 10th, 10, 06:36 PM Thread Starter
Yes, initial 13 deg timing was set without vacuum advance.
1969 Camaro SS
Black Z is offline
post #6 of 15 (permalink) Old Mar 10th, 10, 07:26 PM
AJ
Do you have an adjustable vacuum advance can?
the engine vacuum could be too low for the vacuum it's trying to pull from the distributor.
'68 333" Camaro
'14 5.0 Mustang
ace's68 is offline
post #7 of 15 (permalink) Old Mar 10th, 10, 08:02 PM Thread Starter
Its a Pertonix flame thrower dizzy but I do not know if the advance is adjustable. When the advance is unhooked the rpm does not vary by much so I do not think that is the problem, but am not sure.
1969 Camaro SS
Black Z is offline
post #8 of 15 (permalink) Old Mar 10th, 10, 08:25 PM
Shawn
i had the same problem, but once i advanced the timing a bit more and turned down the idle on the carb it worked fine
my engine only pulled about 12" of vacuum at idle if that helps at all
victimizati0n is offline
post #9 of 15 (permalink) Old Mar 10th, 10, 08:29 PM Thread Starter
I do not think that that will have any change. I played around with the timing and idle for a awhile when dialing it in and it is was still about 500 rpm more in park then in drive no matter what the timing was at.
1969 Camaro SS
Black Z is offline
post #10 of 15 (permalink) Old Mar 10th, 10, 08:43 PM
Shawn
did you check the secondaries and make sure they are not open too far?
post #11 of 15 (permalink) Old Mar 10th, 10, 08:44 PM Thread Starter
I have not checked that but could that even cause this condition?
1969 Camaro SS
Black Z is offline
post #12 of 15 (permalink) Old Mar 11th, 10, 12:30 AM
Make sure your connected to manifold vacuum, not ported vacuum.
When you unhook the line and plug it there should be a noticable change.
Here is a link that gives good info.
https://www.camaros.net/forums/showth...ported+advance
BrewHog55 is offline
post #13 of 15 (permalink) Old Mar 11th, 10, 12:35 AM Thread Starter
I am on full vacuum, but the change is only maybe 200-300 rpm.
1969 Camaro SS
Black Z is offline
post #14 of 15 (permalink) Old Mar 11th, 10, 02:04 AM
AJ
I have the same distributor if it's the coil in cap version. Yes, the vacuum advance can is adjustable, you need a small allen wrench.
My motor would die out under 1,200 rpm or so when I installed a big cam and big runner heads, no velocity, and very little vacuum. I band aid fixed it for a while by running mechanical advance only, try that, if it idles steady, you have eliminated the carb problem.
'68 333" Camaro
'14 5.0 Mustang
ace's68 is offline
post #15 of 15 (permalink) Old Mar 11th, 10, 04:18 AM
X2 on BrewHog's suggestion. Once rpm is up due to full vacuum, you should be able to turn down curb idle, unless secondaries are open a smiggin', or another minute leak.
With a loose convertor, low rpm in neutral, selecting a gear should only drop rpm by about 100-200 rpm.
