is this cylinder cracked? can someone post pictures of a SJ sbc? - Team Camaro Tech
post #1 of 6 (permalink) Old Mar 10th, 10, 07:48 PM Thread Starter
Shawn
i made this thread before, but i didnt want to bring it back from the dead because it kinda went off topic
anyway, can anyone take some pictures of the bottom of their block, SBC, pref. a SJ, i need pictures with no crank so you can see the bottom of the bores
the reason i ask is because a few years ago when i took my 327 block out of the car i noticed a few "chunks" taken out of the bottom of the bore, but im not sure if it is normal or not.
here are some pictures:
you can see what im talking about on the right side of the cylinder
this is cylinder number eight, it looks pretty messed up, im not home right now, so i cant check if any other cylinders are like this, but i dont think they are
on this pic you can see it at the bottom of the cam
Is it possible to tell from these pictures? When i get home i can take new ones, but for now, its all i have.
if it is damaged, should i be worried about building the block? Its not every day that you can find a sj sbc with a stock bore that doesnt need to be bored out, but i would like to rev this little engine as much as possible
thanks for any comments
victimizati0n is offline
post #2 of 6 (permalink) Old Mar 10th, 10, 08:59 PM
scblucam's Avatar
Re: is this cylinder cracked? can someone post pictures of a SJ sbc?
From some that I have seen that looks normal, should probably be cleaned up on a rebuild.
68 302 M20 - 85 IROC Z
scblucam is offline
post #3 of 6 (permalink) Old Mar 11th, 10, 09:47 AM Thread Starter
Shawn
thanks, so do you think it is just a casting error on the block?
can i just get a die grinder and just drind it down?
I dont think it would at all affect the engine, but i just wanted to make sure that is normal, and not a block that had a rod or cam break and smash bits of the engine
post #4 of 6 (permalink) Old Mar 11th, 10, 10:11 AM
Chad
67 Plum's Avatar
Nothing wrong with that at all.Clean it up with a die grinder and go on.
67 Plum is offline
post #5 of 6 (permalink) Old Mar 11th, 10, 06:56 PM Thread Starter
Shawn
thanks, a friend of mine is going to clean the block for me, and im going to take it to the machine shop and get it checked out to see if i can get away with just a hone
post #6 of 6 (permalink) Old Mar 11th, 10, 07:22 PM
AJ
The cylinders actually look pretty good to me, can still see the cross hatching.
It's appears that the dog legs that hang down from the bores are missing, unless pre '68 blocks didn't have them...
'68 333" Camaro
'14 5.0 Mustang
ace's68 is offline
