Carburator vaccum - Team Camaro Tech
post #1 of 8 (permalink) Old Mar 11th, 10, 01:42 PM Thread Starter
gary
Carburator vaccum
can someone please tell me if there is a vaccum line on the carburator and where is this line supposed to go to ? it a 327 2 barrel original engine.
see picture where my finger is pointing to carburator vaccum
http://s679.photobucket.com/albums/v...1.jpg&newest=1
thanks gary
Real canadian67 is offline
post #2 of 8 (permalink) Old Mar 11th, 10, 03:18 PM
ZZ_430's Avatar
Re: Carburator vaccum
Pretty sure that went to the stock aircleaner base. Just plug it if everything else works.
Maybe somebody else can correct me.
Don ~ TC Member #15 ~
Don't mess with Texas!
ZZ_430 is offline
post #3 of 8 (permalink) Old Mar 11th, 10, 03:22 PM Thread Starter
gary
i have the stock air cleaner and nothing there to put a vac hose on,if i plug it ,it almost stalls
post #4 of 8 (permalink) Old Mar 11th, 10, 03:35 PM
Where does the rubber vac hose that is bent at a 90 hook up?
If you plug it and it almost stalls, readjust the idle mixture. It's a vacuum leak that has probably been tuned around.
BPOS is offline
post #5 of 8 (permalink) Old Mar 11th, 10, 03:53 PM
I have a 327 single barrel carb and manifold in storage. Mine has a short hose there that goes to the diaphragm on the choke plate. If you do not need it you can block it off and retune the carb.
68 convertible
ccpeat is offline
post #6 of 8 (permalink) Old Mar 11th, 10, 04:37 PM Thread Starter
gary
this pic shows where the other vac lines are going http://s679.photobucket.com/albums/v...t=P1010643.jpg
post #7 of 8 (permalink) Old Mar 11th, 10, 04:59 PM
Vintage 68's Avatar
Thumbs up Re: Carburator vaccum
That is correct - it was originally for the Choke Pull-Off diaphragm
You lines are not connected right, the line seems to go to a 'T' that is 'T'd again into another line.
Re-route to eliminate the down-stream 'T' ...
1968 Convertible
Some trucks
Vintage 68 is offline
post #8 of 8 (permalink) Old Mar 11th, 10, 05:23 PM Thread Starter
gary
thanks guys ,one more thing how do i get my user name back up here instead of my email address
