PLEASE HELP Engine Casting Numbers - Team Camaro Tech
post #1 of 12 (permalink) Old Mar 12th, 10, 01:59 PM Thread Starter
HI, I just picked up a 72 RS, I haven't had time to get behind the block to look for casting numbers, but on the right front bank casting numbers are stamped in large letter. I can't determine what they are. I searched a few sites and the suffix is not close. Here is the following:
V11250NU in large letters
10(8 or a 3) 170803 in small letters.
Any help would be greatly appreciated. Thank you John
Prayers1 is offline
post #2 of 12 (permalink) Old Mar 12th, 10, 03:19 PM
Vintage 68's Avatar
Wink Re: PLEASE HELP Engine Casting Numbers
Originally Posted by Prayers1 View Post
... V11250NU in large letters
Might want to check that
I think you'll find 'ONU'
1970 Impala 350 w/PG RPO-L65
The other number ('Partial VIN) is most likely 10B170803
For a Baltimore assembled 1970 Impala
1968 Convertible
Some trucks
Vintage 68 is offline
post #3 of 12 (permalink) Old Mar 12th, 10, 09:49 PM Thread Starter
Thank you, Do you know what the HP would be and if it came with a 2 or 4 barrel. I appreciate your effort it's been a big help. John
Prayers1 is offline
post #4 of 12 (permalink) Old Mar 13th, 10, 07:01 AM
A 70 full-size L65 was rated at 250 HP, 2 bbl carb.
Eric
Eric Kammerer is offline
post #5 of 12 (permalink) Old Mar 13th, 10, 09:48 AM Thread Starter
Thank you for the reply, but I am a little confussed. Member Vintage 68 gave the following info "1970 Impala 350 w/PG RPO-L65". Where did he get that info from. I would like to know the compression and cam specs as well. If it came with 2 barrel, then what would an alum intake and 4 barrel boost it up to. This motor came with a 72 RS, I was thinking of replacing it, now 2nd thoughts. Thank you for the valuable info. John
Prayers1 is offline
post #6 of 12 (permalink) Old Mar 15th, 10, 11:34 AM
Vintage 68's Avatar
Thumbs up Re: PLEASE HELP Engine Casting Numbers
My information comes from several sources I've accumulated over the years
I have a hand typed spread sheet I did in the 70's from some GM sources I had access to, a copy of several lists I've been given over the years by fellow 'numbers-guys', a copy of the 1974 Parts Master Cat from GM with all the decode pages in the front, 10~15 different published reference sources from various authors ... you get the idea
I never use one source to quote a given decode, I refer to several and cross-reference the information to see if it makes any sense compared to the unit I'm trying to decode.
Some sources are just dead-wrong, and then they get 're-quoted' by several other sources until they become "fact" Specially see alot of that in the last 10 years or so with the proliferation of data sites on the net. ...
As far as 'installing a 4-barrel and what would it boost power output to' - that's really hard to answer.
Is the engine just the way it left te factory, or did someone rebuild it before installing in you vehicle? It would be a 'normal' procedure to freshen up a used engine during a transplant - even if the owner just went to the nearest "Jiffy Engine" place and bought a replacement assembly.
If so, chances are they used fairly ctock parts and the present output is somewhere near the original factory rating - maybe ...
If you would like to start some improvements in performance I would suggest you start with the exhaust system. A mild set of headers and some reasonably free flowing pipes should net you some noticable 'seat-of-the-pants' improvement and get you should be set for more HP upstream.
Then I'd check the cam and install a mild 268~272 range cam and a dual-plane aftermarket intake manifold to match your selected 4-barrel carb.
All the above should serve to wake-up your present engine for a reasonable price. A HP output estimate would probably be in the @275~<300 range - depending on choices.
From there, the sky is the limit
You'll need to seriuosly consider where you want to go next - if you wanted more HP after that, you'd need to consider the bottom-end and heads in the equation - and things start getting expensive quickly at that point
Hope this helps some, and others chime in;
1968 Convertible
Some trucks
post #7 of 12 (permalink) Old Mar 20th, 10, 04:08 PM Thread Starter
Thank you for the detailed information. I really appreciate it. Here is a picture of the smaller numbers. It looks like a J instead of a B. Also, you are correct in that the suffix letter is a C not a O. Can you give me your opinion on what you think the smaller number mean. I thank you for your time. John
I don't think the picture carried over. I'm a little lost in this department. Can you send your email and I can send it to you that way?
Prayers1 is offline
post #8 of 12 (permalink) Old Mar 20th, 10, 04:19 PM
Bryon
bcm66's Avatar
Sorry to barge in.
Well if it is 10J170803 - the J means Janesville, WI - the vehicle assembly plant. They built Impalas there.
1 = Chevrolet
0 = 1970
J = Janesville, WI
170803 is the unit production number.
68 Camaro SS 396 - 468 BBC now, M21, 12 bolt 3.73 coded housing but w/ 3.31 gears.
Looking for 68 Camaro with body number NOR 181016
CRG -
bcm66 is offline
post #9 of 12 (permalink) Old Mar 20th, 10, 06:35 PM Thread Starter
Thank you BCM66. I appreciate the barge in. I can use as many brains as possible. This site is GREAT. I never experienced so many helpful people. Thank you again! John
Prayers1 is offline
post #10 of 12 (permalink) Old Mar 20th, 10, 06:48 PM Thread Starter
Here's a picture I hope it uploads[/IMG]
Prayers1 is offline
post #11 of 12 (permalink) Old Mar 20th, 10, 07:32 PM Thread Starter
Let me know if this works
Prayers1 is offline
post #12 of 12 (permalink) Old Mar 20th, 10, 09:01 PM
Bryon
bcm66's Avatar
Yes, it worked. And that is a pretty good picture too.
CRG -
bcm66 is offline
