Carb help needed - Team Camaro Tech
post #1 of 4 (permalink) Old Mar 13th, 10, 05:39 AM Thread Starter
Patrick
Carb help needed
I'm working on a customers 85 Silverado. I think it has some kind of computer in it. I took out the old engine and installed a new one. Well he said he wanted all of the smog stuff gone so I removed everything I thought that could be thrown away. It had a million dry rotted vacuum lines so I snatched them out.
It runs great 1/4 to full throttle. At idle it spudders and runs rough. There is a electric plug on top of the quadrajet carb that I think is the problem. I can disconnect it and nothing changes. Anyone have any ideas?
69RS/SS,383,10:1cr,4.10,60ft1.6sec,1/[email protected],1/[email protected],Vicjr,RPMheads,750dp, Proform main body, cam,246*-250*@.050,.510,522,1.6rr,700r4,3200stall
383 IS SOLD!
Building a 489BBC
speedfreek is offline
post #2 of 4 (permalink) Old Mar 13th, 10, 07:43 AM Thread Starter
Patrick
Re: Carb help needed
Ok guys, I went outside this morn and cranked it up for the first time today and it ran like a sewing machine. I drove it down the road to let it get up to temp and it still ran great. Glad it fixed itself! Any ideas what it was?
383 IS SOLD!
Building a 489BBC
post #3 of 4 (permalink) Old Mar 13th, 10, 08:15 AM
DT
Donny
DT's Avatar
1985 did have a computer OBD I. 1996 and later OBD II.
DT is offline
post #4 of 4 (permalink) Old Mar 13th, 10, 08:38 AM
Smile Re: Carb help needed
The carburetor and distributor are computer controlled. If you really want it to be non-computer, both must be changed to the older style. You will need a vacuum advance distributor and no electrics on the carburetor. (An electric choke is OK)
TJS69 is offline
