sbc 400 engine vibration - Team Camaro Tech
post #1 of 15 (permalink) Old Mar 13th, 10, 11:26 PM Thread Starter
James
Hi, I recently installed a new scat 9000 cast crank and new bearings in my 400 sbc. I now have a vibration ( on scale of 1-10 about a 6) that shows up at about 2200rpm. It then gets better once the rpm increases. It does this with the transmission in any position, even park or neutral or while driving. I installed this crank because the stock crank had excessive wear on the thrust plate. I didn't rebuild the engine, therefore did not take it all apart. I installed the flexplate with the dowel pin holes lined up. There was no dowel pin though. I also had a new TCI torque convertor installed. I have the correct harmonic balancer and the correct weighted 168 tooth flexplate for the 400 sbc. Do you I need to have the dowel pin installed to balance the components? Should I have had the parts balanced by a machine shop? If so, what parts do I need to take to have them balanced properly? Any help would be appreciated!
James
Espanola, New Mexico
67 RS/SS click my profile to see pic
james_m_ag is offline
post #2 of 15 (permalink) Old Mar 14th, 10, 05:18 AM
Harry
dawg's Avatar
Re: sbc 400 engine vibration
crank NEEDS to be balanced with the balancer and flexplate installed.
434 stroker
US Navy retired
dawg is offline
post #3 of 15 (permalink) Old Mar 14th, 10, 06:37 AM
I would guess that SCAT crank is internally balanced, and you need a neutral balanced flex plate and harmonic balance wheel now too, not the original 400 which is externally balanced.
69 Pace Car and 69 Hard top
srode is offline
post #4 of 15 (permalink) Old Mar 14th, 10, 06:50 AM
Harry
dawg's Avatar
so first you gotta find out which crank you have then go from there.
434 stroker
US Navy retired
dawg is offline
post #5 of 15 (permalink) Old Mar 14th, 10, 07:58 AM
Banned
Originally Posted by dawg View Post
crank needs to be balanced with the balancer and flexplate installed.
x2
CNC BLOCKS N/E is offline
post #6 of 15 (permalink) Old Mar 14th, 10, 12:09 PM Thread Starter
James
The crank is an externally balanced crank from Scat. Im not an engine builder, so I appreciate any help. Is it common practice to have a new crank balanced with flexplate and flywheel? Does the dowel pin in crank have to be installed to be balanced?
James
post #7 of 15 (permalink) Old Mar 14th, 10, 01:35 PM
Harry
dawg's Avatar
yes and definately yes
434 stroker
US Navy retired
dawg is offline
post #8 of 15 (permalink) Old Mar 14th, 10, 01:50 PM Thread Starter
James
Thanks for the reply Dawg! I will take crank out and take crank, dampner, and flywheel to machine shop. any other suggestions or info I need to give to machine shop?
James
post #9 of 15 (permalink) Old Mar 14th, 10, 03:25 PM
I had something similar (vibration at low RPMs) and took me about a month to find it.... found by accident too
While under my truck for a problem, the exhaust sound was off and I couldn't figure it out.
Long story short... broken exhaust valve spring killing A/F mixture
68 Camaro~LSx ~all motor
post #10 of 15 (permalink) Old Mar 14th, 10, 04:30 PM
If you're taking it that far apart, take the NUMBERED pistons/rods and have the whole shebang balanced.
BPOS is offline
post #11 of 15 (permalink) Old Mar 14th, 10, 06:55 PM Thread Starter
James
Well, I do have the six inch scat rods sitting on the shelf. I was buying parts slowly so I could rebuild it right next summer. I'm thinking that the rebuild time is now. Any suggestions from you guys which pistons to get. I have the 400sbc two bolt main. Scat 9000 stroker lightweight crank for the 400sbc with a 3.75" stroke and 5.7" rod length. . Scat forged I-beam connecting rods 6" . A new Comp cams part # cs xe262H-10 camshaft and lifter kit. How do I figure out which pistons to get. Being that the crank is for a 5.7" rod and I am going to use 6"rods. I got crank and rods on craigslist for $250 all sealed and brand new in boxes. Any idea would be greatly appreciated. Also, what would the combo produce as far as cubic inches and compression ? Any concerns with this build? As for heads, I am using some stock 76cc heads, but plan on upgrading to some aftermarket heads in the future. Can't afford it now, but I understand how a good set of heads would make a huge difference. The pistons would have to be able to clear these stock heads for now. My car will be mostly street driven, weekend strip occassionally. I like to have the power when I want it, but it needs to be streetable. Thanks for any info.
James
post #12 of 15 (permalink) Old Mar 14th, 10, 07:12 PM
Bill
James,
The Scat 9000 cranks are not balanced at all from the factory. YOu need to have the crankshaft balanced to the weights of your parts (pistons, rings, rods etc) You dont actually have to have the dowel pin, but it makes certain that you install the flywheel in the proper position.
Any good machine shop that does engine balancing should be able to tell youexactly what you need to do.
Bill Koustenis
Owner
Advanced Automotive Machine
Waldorf Md
BillK is offline
post #13 of 15 (permalink) Old Mar 14th, 10, 07:16 PM Thread Starter
James
Thanks for the help Bill. I will dissassemble and take in. Once again, thanks!
James
post #14 of 15 (permalink) Old Mar 14th, 10, 09:07 PM Thread Starter
James
I am going to start a new thread on perfomance, thanks for the help guys.
James
post #15 of 15 (permalink) Old Mar 15th, 10, 08:42 AM
Wes
This is a long-shot, but I once solved a vibration problem by inspecting the radiator fan. The previous owner had installed an aftermarket flex fan and half of one of the blades was missing. Swapped for a factory 5 blade fan and she smoothed out perfectly.
FWIW
Straight-line-69 is offline
