Q-jet question - Team Camaro Tech
post #1 of 7 (permalink) Old Mar 14th, 10, 10:00 AM Thread Starter
Q-jet question
Hello all,
I have a question regarding the Rochester Quadrajet.
Will a q-jet 7028213 DY for a manual tranny work with a automatic transmission?
I need the 7028212 DH, but was told the 7028213 DY will work with the automatic.
Does it matter, or will either one work on my 327/275 auto '68 Camaro?
Thanks for the help and clarification.
brewcity is offline
post #2 of 7 (permalink) Old Mar 14th, 10, 01:11 PM
Smile Re: Q-jet question
Either should work. One difference between the automatic and stick shift carburetors is the lack of linkage for a kickdown switch or rod etc. (or a kickdown cable if transmission is a TH350 from a '69 or newer).
TJS69 is offline
post #3 of 7 (permalink) Old Mar 14th, 10, 02:09 PM Thread Starter
Re: Q-jet question
OK...thanks for the help.
If I get the manual carb, can you buy and install the linkage for a kickdown switch or rod if you needed one?
brewcity is offline
post #4 of 7 (permalink) Old Mar 14th, 10, 04:59 PM
Do you have the old carburetor to take it from ?
TJS69 is offline
post #5 of 7 (permalink) Old Mar 14th, 10, 05:16 PM Thread Starter
Re: Q-jet question
I do have an old 2 barrel carb, yes. Will that work?
brewcity is offline
post #6 of 7 (permalink) Old Mar 14th, 10, 07:37 PM
Bill
Re: Q-jet question
no, The linkage does not unbolt from the Q-jet like on some carbs. You need to get a Q-jet that is made for an automatic unless you want to do some fabricating and make the correct arm and bolt or weld it to the Q-jet you buy.
Bill Koustenis
Owner
Advanced Automotive Machine
Waldorf Md
BillK is offline
post #7 of 7 (permalink) Old Mar 14th, 10, 08:21 PM Thread Starter
Re: Q-jet question
OK...thanksfor the clarification...so if i do NOT want to fabricate, make sure it is for an automatic, or it wont work? Is that right?
brewcity is offline
