Cowl induction air cleaner question - Team Camaro Tech
post #1 of 7 (permalink) Old Mar 14th, 10, 03:42 PM Thread Starter
JFK
JAY
I cave a cowl hood with the hood insulation on it. I installed a cowl air cleaner and the rubber seal hits the insulation. Is that right or is it suposed to be tight to the metal of the hood itself. I have no room for triming because the retainers are there. Would like to keep it but i also want the cowl to work properly. Any advice would be great.
JFK is offline
post #2 of 7 (permalink) Old Mar 14th, 10, 03:50 PM
Re: Cowl induction air cleaner question
Jay that sounds like you have a standard hood insulation and not the cowl one, or maybe if you do have a cowl insulation then it does not have a correct sized hole cutout. The cowl insulation has a big cutout which allows the air cleaner assembly to sit in the cowl hole without being fouled by anything.
Indy 69 is offline
post #3 of 7 (permalink) Old Mar 14th, 10, 05:40 PM Thread Starter
JFK
JAY
It has the hole cut out and it is larger than the hole in the hood. I got it from Ricks. Maybe thats the problem.
JFK is offline
post #4 of 7 (permalink) Old Mar 14th, 10, 05:50 PM
Fred
I was gonna suggest getting rid of the insulation. I don't like the stuff because it holds dirt and can't be washed. Of course, who drives in dirt? If it's new, maybe Ricks will take it back. Here's my cowl, no insulation.
128.79mph 1.428 60'
Fred Ficarra is offline
post #5 of 7 (permalink) Old Mar 14th, 10, 06:18 PM Thread Starter
JFK
JAY
Do you run a spacer plate. You got a small block? What size are those wheels? Looks good.
JFK is offline
post #6 of 7 (permalink) Old Mar 14th, 10, 07:11 PM
Kevin
KevinW's Avatar
Make sure you seal is right side up, if it is upside down, it could hit the insulation
Kevin
KevinW is offline
post #7 of 7 (permalink) Old Mar 14th, 10, 07:41 PM
mark
mark x22's Avatar
mark x22 is offline
