BBC Frame Mounts - Team Camaro Tech
post #1 of 12 (permalink) Old Mar 15th, 10, 06:45 AM Thread Starter
BBC Frame Mounts
I'm in the middle of a big block conversion and had a question about the frame mounts. I have the correct frame mounts which I ordered from NPD.
My question is, they attach in the same holes as the small block mounts, correct? No need to drill new holes?
I already had my trans cross member fitted for the big block by a body shop.
Thanks for the advise.
JB's68toy is offline
post #2 of 12 (permalink) Old Mar 15th, 10, 07:07 AM
red
Re: BBC Frame Mounts
No drilling to be done. Make sure you get correct motor mount / frame mount setup.
red67L78 is offline
post #3 of 12 (permalink) Old Mar 15th, 10, 09:29 AM
Smile Re: BBC Frame Mounts
The Big Block transmission crossmember moves the transmission mounting location, 1/2" to the passenger side and 3/4" forward from the small blocks location.
TJS69 is offline
post #4 of 12 (permalink) Old Mar 15th, 10, 07:33 PM
DT
Donny
DT's Avatar
Guys, I'm having a tough time with this diagram. It seems to me the front of the car should be marked rear, and the rear of the car should be marked front. I have a BB 4 speed crossmember in my hand as of this writing. The slant under the x member should be top right which faces the rear.
DT is offline
post #5 of 12 (permalink) Old Mar 16th, 10, 12:36 AM
The diagram is correct. The BBC is moved 1/2" to the passenger side and 3/4" forward from the small block location.
View it from underneath the car looking up. The actual picture of the crossmember shows the bolt holes for the shifter (on some years) is to the driver's side.
TJS69 is offline
post #6 of 12 (permalink) Old Mar 16th, 10, 06:09 AM
DT
Donny
DT's Avatar
Bolt holes for the shifter??? What bolt holes for the shifter??? Looking underneath the car the notch/slant(trans mount holes) should be on the right side. The cutout/indent on top of the crossmember is for the shifter correct?? If yes, its on the drivers side and if the cutout/indent is on the drivers side, then the notch/slant is on the right.
DT is offline
post #7 of 12 (permalink) Old Mar 16th, 10, 06:37 AM
DT
Donny
DT's Avatar
Here is a photo.
Name:	2010-03-16 08.28.01.jpg
DT is offline
post #8 of 12 (permalink) Old Mar 16th, 10, 08:56 AM
Yes, the three bolt holes on the edge of the crossmember are for OE shifter moiunting and they are on the drvr side.
On top of the crossmember where the trans mount interfaces/sits on, is slanted and the slant faces the front of the car.
post #9 of 12 (permalink) Old Mar 16th, 10, 10:57 AM
DT
Donny
DT's Avatar
Figive me?? Isn't the shifter mounted on the side of the Muncie only with a BB mounting plate?? I didn't know the mounting plate bolted to the crossmember ?? If thats what you mean? Also I thought the cutout/indent on top of the crossmember was for the shifter. If what you say is correct, the cutout/indent on top of the crossmember is on the passenger side??? That maybe where my confusion is, I always thought that the indent was on the drivers side for the shifter.
DT is offline
post #10 of 12 (permalink) Old Mar 16th, 10, 11:37 AM
red
The 3 bolt holes are for the shifter. 2 on rear and 1 in front. There was no difference from BBC or SBC for shifter mount.
red67L78 is offline
post #11 of 12 (permalink) Old Mar 16th, 10, 01:27 PM
Not all the shifters mount to the crossmember... only certain years/transmissions do.
That cutout is not for the shifter. It is for clearance on certain transmissions.
TJS69 is offline
post #12 of 12 (permalink) Old Mar 16th, 10, 02:46 PM
DT
Donny
DT's Avatar
Oh Thanks Tom, for some reason, I thought that indent was for the shifter.
DT is offline
