BBC Cross member - Team Camaro Tech
post #1 of 5 (permalink) Old Mar 15th, 10, 08:00 PM Thread Starter
Question BBC Cross member
Why do you have to have bb cross member? I have a tb400 cross member and trans in my car,but don't no wheather it bb or sm block. How can i tell? Ihave a bb in the car.
dill is offline
post #2 of 5 (permalink) Old Mar 15th, 10, 08:22 PM
Cool Re: BBC Cross member
Not sure if I am missing something here, but the big block crossmember you may have read about is for the big block manual cars.
Indy 69 is offline
post #3 of 5 (permalink) Old Mar 15th, 10, 08:32 PM
The Turbo 400 was only used behind bigblocks, so if you're using a stock T400 style crossmember then that is a BB crossmember. Measure it and you'll see it mounts the trans offset toward the passenger side of the car.
Same is true for a BB manual trans crossmember, except it looks just like a small block crossmember, until you get the measuring tape out (or inspect it closely, 1 corner of the whole where the trans bolts are is cut at a 45)
post #4 of 5 (permalink) Old Mar 15th, 10, 08:41 PM
DT
Donny
DT's Avatar
This thread was just under your thread.
https://www.camaros.net/forums/showthread.php?t=175780
DT is offline
post #5 of 5 (permalink) Old Mar 16th, 10, 08:13 AM Thread Starter
Unhappy Re: BBC Cross member
Ok thanks guys i understand now.
dill is offline
