MSD distributer - Team Camaro Tech
post #1 of 9 (permalink) Old Mar 16th, 10, 03:22 PM Thread Starter
MSD distributer
For a chev small block using a billet MSD electronic distributer do you keep the 2 "O" rings that are on the bottom of the housing or remove them?
XRAM is offline
post #2 of 9 (permalink) Old Mar 16th, 10, 03:25 PM
DT
Donny
DT's Avatar
Re: MSD distributer
You mean the fiber gaskets ? If yes, I would use just one.
DT is offline
post #3 of 9 (permalink) Old Mar 16th, 10, 03:27 PM
Ken
Re: MSD distributer
The "O rings" on the shaft right? I left mine out.
1969 Camaro
KMG69 is offline
post #4 of 9 (permalink) Old Mar 16th, 10, 03:36 PM
Harry
dawg's Avatar
Re: MSD distributer
I used mine after my oil pressure was kinda low after I installed MSD distributor.
MSD tech said reinstall and my pressure came back.
434 stroker
US Navy retired
dawg is offline
post #5 of 9 (permalink) Old Mar 16th, 10, 03:41 PM Thread Starter
Re: MSD distributer
Yes I am talking sbout the 2 actual "O" rings on the actual housing just above the distributer gear
XRAM is offline
post #6 of 9 (permalink) Old Mar 16th, 10, 04:23 PM
ZZ_430's Avatar
Re: MSD distributer
Not to be used unless your block has been modified. I've tried and it just tears them up.
Scroll down to note 2:
http://www.jegs.com/InstallationInst...1/121-8558.pdf
Don ~ TC Member #15 ~
Don't mess with Texas!
ZZ_430 is offline
post #7 of 9 (permalink) Old Mar 16th, 10, 05:27 PM
Ken
Re: MSD distributer
Yes, the block requires machining for the "O rings" to work.
1969 Camaro
KMG69 is offline
post #8 of 9 (permalink) Old Mar 16th, 10, 05:31 PM
Fred
Re: MSD distributer
Good lord, what happened to a simple distributor change? These are Chevy's for the love of my torque wrench! And what's rotor phasing??? Plus I've got one of these on my BBC. After two seasons of racing with it, the O rings are just fine without touching the block.
128.79mph 1.428 60'
Fred Ficarra is offline
post #9 of 9 (permalink) Old Mar 17th, 10, 09:23 AM
Bill
Re: MSD distributer
My MSD Dist. has been put in a 2-piece rear main seal block and the newer 1-piece seal block and didn't use these on either. No oil issues. I recall the instructions specified the conditions when the O-rings were applicable as mentioned above.
68RS-SS is offline
