Alt Bracket Set Up for BBC - Team Camaro Tech
post #1 of 12 (permalink) Old Mar 17th, 10, 01:55 PM Thread Starter
Help!!! Hope this is the correct forum.
I am having trouble setting up my alt bracket for my BBC, short water pump, driver side mount. I ordered the correct bracket for a 68 bbc with a short wp. This issue is the top bracket needs to mount into the intake and I don't have a spot to attach (new Weiland Stealth intake).
My question is, where can I get the correct bracket for this set up? I looked at March but most are all for a long water pump. I want to make it look as original as possible. any suggestions????
Any advise would be greatly appreciated!!!
Thanks,
JB's68toy is offline
post #2 of 12 (permalink) Old Mar 17th, 10, 02:04 PM
BILL
SPARKY69's Avatar
Re: Alt Bracket Set Up for BBC
www.zoops.com
BILL D.
JOHN 3:16
SEMPER FI
SPARKY69 is offline
post #3 of 12 (permalink) Old Mar 17th, 10, 02:07 PM
Bri
bwcamaro68's Avatar
Thats a bit hard to use a bracket that is intended for a stock intake. Yours not being stock.
where can I get the correct bracket for this set up? I looked at March but most are all for a long water pump. I want to make it look as original as possible. any suggestions????.
same thing Original parts could use the bracket you ordered. You will need to relocate your brackets or Fab up something different all together, due to the fact of the intake change.
Here is one close to what your looking for? Maybe?
https://www.camaros.net/forums/showth...ht=alt+bracket
As Bill has mentioned the possible use of Zoops brackets.
thanks Bill
"Three Rules of Work: Out of clutter find simplicity; From discord find harmony; In the middle of difficulty lies opportunity."
Albert Einstein
"Never Forget" FDNY 9/11/01
I have more than 4 Camaro's am I Addicted?
bwcamaro68 is offline
post #4 of 12 (permalink) Old Mar 17th, 10, 02:23 PM
Smile Re: Alt Bracket Set Up for BBC
http://www.alangrovecomponents.com They will have one.
TJS69 is offline
post #5 of 12 (permalink) Old Mar 17th, 10, 03:01 PM Thread Starter
Will this work?
post #6 of 12 (permalink) Old Mar 17th, 10, 03:07 PM
ZZ_430's Avatar
Will this work?
Same thing I was using.
It mounts using a water pump bolt. It's a stock GM bracket but I don't have the part #
Name:	Shop ZZ 030.jpg
Don ~ TC Member #15 ~
Don't mess with Texas!
ZZ_430 is offline
post #7 of 12 (permalink) Old Mar 17th, 10, 03:16 PM Thread Starter
Nice engine! What about the lower bracker, is that the stock one?
Thanks again for your help!
post #8 of 12 (permalink) Old Mar 17th, 10, 03:24 PM
ZZ_430's Avatar
John, yes stock GM lower bracket. I haven't found an aftermarket one any better.
ZZ_430 is offline
post #9 of 12 (permalink) Old Mar 17th, 10, 03:31 PM Thread Starter
Don, That's fine with me, I just want to mount my alt and still keep that original look.
I also see you have the same pulleys as me, however my water pump and crank pulley's do not line up. I have a short water pump, one groove pulley's on both wp and crank (looks exactly like yours) but they don't line up. Might sound like a dumb question but do your pulley's line up exactly? don't know why mine are off. might need to go with a double groove crank pulley.
Thanks again
post #10 of 12 (permalink) Old Mar 17th, 10, 03:53 PM
ZZ_430's Avatar
They didn't line up at first try, I had to use shims on the crank pulley. Summit carries shims (Moroso) for both the WP and crank pulley.
Then the alternator needed a washer to line up, between the bracket and the alt.
ZZ_430 is offline
post #11 of 12 (permalink) Old Mar 17th, 10, 04:05 PM Thread Starter
My crank is off by a 1/2 inch. Looks like a double groove crank pulley would do the trick. Will also order extra shims just in case.
Would you happen to have any other pics of your engine set up? I would love to reference your engine bay, looks like the same set up as mine. I just can't wait to be done with this project and just drive the car, ha ha.
Thank you again.
post #12 of 12 (permalink) Old Mar 17th, 10, 04:11 PM
ZZ_430's Avatar
Thumbs up Re: Alt Bracket Set Up for BBC
John, you've got a PM.
ZZ_430 is offline
