Slight hesitation - Team Camaro Tech
post #1 of 6 (permalink) Old Mar 18th, 10, 07:50 AM Thread Starter
foreverlookin's Avatar
Slight hesitation
I noticed it a while ago at low RPM say between 1500 and 2000 its like it is stumbling and once I'm through that band its great or if I rev it and go its fine. Its a SBC with a mild cam MSD ignition system demon 650 with mech sec. Timing seems fine. I went through and checked for vac leaks but am baffled as to where to look next. Any hints?
foreverlookin is offline
post #2 of 6 (permalink) Old Mar 18th, 10, 08:23 AM
Skip
Skeeter55's Avatar
Re: Slight hesitation
Try this link sounds like a accelerator pump could have a stretched/cracked or bad diaphragm. But this link that a member posted yesterday is vary good to check the vacuum and helps tunning.
http://www.centuryperformance.com/tu...e-spg-148.html
I NEED TO HIT THE LOTTERY
Skeeter55 is offline
post #3 of 6 (permalink) Old Mar 18th, 10, 12:56 PM Thread Starter
Thanks for the link Skip. By chance was the picture of your car in front of the fountain taken at Trump National?
post #4 of 6 (permalink) Old Mar 18th, 10, 03:03 PM
Skip
Skeeter55's Avatar
No but that would be an awesome photo.
post #5 of 6 (permalink) Old Mar 18th, 10, 03:42 PM
Keith
Check the air filter--bothe size and for obstruction (too dirty)...lack of or restricted airflow into the carb will cause a similar hesitation...
Keith
1967 Camaro
Muncie M-20
GM 8.5, 3.73 posi
keithl1967 is offline
post #6 of 6 (permalink) Old Mar 18th, 10, 05:32 PM
Steps
Check the accerator pump is set up correct
how to in older posts...need 3 hands
Steptoe is offline
