Wierd sound when I get on it - Team Camaro Tech
post #1 of 5 (permalink) Old Mar 20th, 10, 10:53 AM Thread Starter
When I really get on the gas in 1st or 2nd I am hearing what sounds like rattling from the engine (like nails in a tin can being shaken). Any ideas, I am not sure what detonation sounds like, could my time be advanced to far? The car does not struggle to start but sometimes (not always) I get a little run on when I shut it down.
Any thoughts out there?
1969 Camaro SS
350/300 M20
12 Bolt 3:73 Posi
Myfirst 69SS is offline
post #2 of 5 (permalink) Old Mar 20th, 10, 11:46 AM
68driver57's Avatar
Re: Wierd sound when I get on it
What is your compression ratio? Sounds like pinging, you might need to step up the octane to make this go away.
68 coupe
matching 327
95 coupe (bone stock)
68driver57 is offline
post #3 of 5 (permalink) Old Mar 20th, 10, 02:06 PM Thread Starter
Not certain of the compression ratio. I only put 93 octane in it.
1969 Camaro SS
350/300 M20
12 Bolt 3:73 Posi
post #4 of 5 (permalink) Old Mar 20th, 10, 02:07 PM
Harry
dawg's Avatar
back off on the timing a few degrees and see if it still does it.
434 stroker
US Navy retired
dawg is offline
post #5 of 5 (permalink) Old Mar 20th, 10, 03:38 PM
Steve O.
X-2......struggling starter also indicates to much initial timing.
67' Vert RS Tremec TKO- Eaton 3:55- 350 cu.- L98 heads-Vintage Air- Torque Thrust-BFG.g-force 4-wheel disc.
67motorcat is offline
