Hood clearance issues ? - Team Camaro Tech
post #1 of 4 (permalink) Old Mar 20th, 10, 11:23 AM Thread Starter
Clint
Smile Hood clearance issues ?
Installed 396 in 67 coupe camaro used big block frame mts. carb is .5 in. from hood. she wants stock hood no scoop. is it possible ?
mccann is offline
post #2 of 4 (permalink) Old Mar 20th, 10, 12:20 PM
Smile Re: Hood clearance issues ?
1st - a big block was an SS, and SS hoods allow a little more room.
2nd - you need the correct height intake manifold.
3rd - you need the correct air cleaner
TJS69 is offline
post #3 of 4 (permalink) Old Mar 21st, 10, 09:16 AM Thread Starter
Clint
Yes i figure there is no way around it however i told her i would try , investigating a liitle more. Does the correct air cleaner have a drop base ? And what would be the correct height on the intake ? I am running a Torker -2 which is about 4.25 inches .
mccann is offline
post #4 of 4 (permalink) Old Mar 21st, 10, 10:51 AM
I have heard that the torker or torker 2 are short. Yes, a Drop base air cleaner is needed.
TJS69 is offline
