Paul
Re: Gassssssss
If the compression is low enough, (and on a stock 327 it just might be) you shouldn't need the higher octane. I had some discussions with my technicians about the use of premium vs regular grade in normally aspirated engines quite a while ago, and if I recall their opinion correctly higher octane fuel is more difficult to ignite in the combustion chamber and therefore the lower octane or mid grade will burn more completely.
There are of course many other factors that can influnce this, but try some regular grade and maybe make a few timing adjustments. You just might be able to save 10 cents a litre or so.
Paul
'69 Camaro, 250 inline 6, EFI Turbo rebuild is running!!
, CC5S TKO 500, and more.
V8 Camaros are like navels......Everybody has one.
The Toad. 1970 base Camaro (Navel), 350, turbo 700R4, 3.73 posi, Hotchkis TVS system,
Mrs. McGoo's & McGoo Jr.'s toy
