1967 327 - Team Camaro Tech
post #1 of 11 (permalink) Old Mar 23rd, 10, 10:01 AM Thread Starter
1967 327
What's the best way to block off this crankcase vent?
1981Zapper is offline
post #2 of 11 (permalink) Old Mar 23rd, 10, 10:04 AM
Bri
bwcamaro68's Avatar
Re: 1967 327
Thats the hole for your distributor....and tie down bolt
"Three Rules of Work: Out of clutter find simplicity; From discord find harmony; In the middle of difficulty lies opportunity."
Albert Einstein
"Never Forget" FDNY 9/11/01
I have more than 4 Camaro's am I Addicted?
bwcamaro68 is offline
post #3 of 11 (permalink) Old Mar 23rd, 10, 10:25 AM
Re: 1967 327
That hole is for the old road draft tube. Install a 1 1/4" freeze plug.
The small threaded hole is for your oil pressure sending unit.
Make sure to run PCV valve on one valve cover and breather cap on the other.
67 Convertible, LS1, T56
rockportag03 is offline
post #4 of 11 (permalink) Old Mar 23rd, 10, 10:40 AM
dondb's Avatar
Re: 1967 327
What kind of car you putting the 327 in? If it's 69 Camaro...make sure you change the motor mounts, the 69 camaro with v8's had a different frame mount.
69 X-44 Camaro, slowly upgrading to my liking...Hmmm, i guess i'll never be done
2002 Camaro LE SS...Many upgrades
1969 Step Side LWB C10
dondb is offline
post #5 of 11 (permalink) Old Mar 23rd, 10, 10:45 AM Thread Starter
Re: 1967 327
Its going into my 81 Z
post #6 of 11 (permalink) Old Mar 23rd, 10, 02:28 PM
mbrekke's Avatar
Re: 1967 327
It may not run very well if you plug it...
68 327 4-speed 3.42 posi and a sunroof
best so far... 13.25 at 106mph
78 Firebird 350/T350 3.23 posi
65 Mustang convert. 6 cyl. 3-speed
66 Mustang coupe 6 cyl. auto
80 Chevy C10 406 4-speed
mbrekke is offline
post #7 of 11 (permalink) Old Mar 23rd, 10, 02:44 PM
Re: 1967 327
The hole to the left in pict.is your oil sending unit, is the old style pvc, older is road draft
tube. It has been a long time since I put a plug in that hole, But bI think it IS 1 1/4,
freeze plug, I do know the hole in the intake is 1 1/4,
john68 is offline
post #8 of 11 (permalink) Old Mar 23rd, 10, 07:29 PM
dondb's Avatar
Re: 1967 327
Just make sure you check the motor mounts on the 327 and the frame mount to make sure they mate up properly.
From CRG
All '67-'68 small-block (SB) and '69 307ci and 327ci engines used the same frame mount bracket (approximately 2-1/2 inches wide) attached to the subframe. The 1969 302ci and 350ci engines used a shorter (~3/8 inch) and narrower (~1/4 inch) bracket. 1967-68 engine mounts will assemble to the 1969 302/350 engine mount bracket, but this is an incorrect assembly that results in driveline vibration and clutch chatter because the engine sits too low and can move on the bracket
dondb is offline
post #9 of 11 (permalink) Old Mar 24th, 10, 05:04 PM
Bri
bwcamaro68's Avatar
Re: 1967 327
Ok i had a brain fart
Albert Einstein
post #10 of 11 (permalink) Old Mar 24th, 10, 08:06 PM
scblucam's Avatar
Re: 1967 327
What is that in the back of the head?
68 302 M20 - 85 IROC Z
scblucam is offline
post #11 of 11 (permalink) Old Mar 25th, 10, 06:02 AM
Re: 1967 327
I believe that is a heat sencer. Tells the rebuilder if you over heated the motor
67 royal plum L78 11.70's @115
69 RS Z28 cross-ram
68 convt. all orig 2nd owner
67 396 royal plum impala 4spd parchment int
green z is offline
