Stewart EMP 13113 alternator bracket mount wrong - Team Camaro Tech
post #1 of 11 (permalink) Old Mar 23rd, 10, 07:55 PM Thread Starter
I just got done bolting on my stewart water pump from Summit and the bolt hole for the upper alternator mounting bracket is so far back as compared to the original pump that my alternator bracket TRD9320 is behind the alternator instead of in front making it impossible to mount the alternator. I checked measurements compared to a couple of other pumps in my garage and this one is definitely wrong - it is a long pump but the hole is et back too close to the block to work at all. Sent a note to Summit to see what they can do, but unforunately the pump is painted and the box it came in is long gone. Anyone else have a similar problem with a Stewart pump? They said its the same body as origional when I emailed and asked them about it - just revised inside. I'm wondering if this is a fluke or if they are all like this? Frustated a little bit - I'm stuck now.... till I get a response from Summit I guess. Sent a note to Stewart about the problem too.
69 Pace Car and 69 Hard top
srode is offline
post #2 of 11 (permalink) Old Mar 23rd, 10, 08:31 PM
Smile Re: Stewart EMP 13113 alternator bracket mount wrong
You may have that same problem with a different pump. It may work just fine for a guy down the street. You may be able to fix your problem with a simple spacer. Here is a pic of my Long pump set up that I needed to add a spacer.
TJS69 is offline
post #3 of 11 (permalink) Old Mar 23rd, 10, 09:24 PM
Linnie
I recently purchased a new water pump for my 69 from NAPA. It came with the needed spacer which is about 5/8 of an inch wide. Not sure why they started doing this?
Okie69 is offline
post #4 of 11 (permalink) Old Mar 24th, 10, 12:40 AM
in 75 or 76- when they started painting the engines light blue instead of orange- Chevy changed the front accessory mounts to a more complicated and ugly setup, and the water pump had a couple of things changed to accommodate the changes. the alt bracket mount is farther back, and the PS mount is no longer drilled all the way thru and offset about 1/8" farther back. i think they also put the timing tab in the straight up position at this time so you had to risk falling into the spinning belts and fan blades just to set your timing. i think they also moved the oil dipstick to the other side of the engine for some reason, too.
all these changes are among the most pointless "refinements" they made to the small blocks over the years.
you don't plan sincerity.
novaderrik is offline
post #5 of 11 (permalink) Old Mar 24th, 10, 04:12 AM Thread Starter
I'm going to look at the power steering mount as well now - it might be different.
srode is offline
post #6 of 11 (permalink) Old Mar 24th, 10, 07:52 AM
I had problems with the alt upper bracket with the spacer but found it was an issue with the rear mounting point using an Airgap intake. I could have jerry rigged it but went to a nicer looking billet adjustable rod here. The lower mount bracket remained the same using a Stewart pump.
TC # 349
zdld17 is offline
post #7 of 11 (permalink) Old Mar 24th, 10, 04:25 PM Thread Starter
Yep, I am not using the stock upper bracket but I would have to use a spacer to get it to work with the location of the upper mounting hole and my chromed 2 point mount - how did you adjustable rod work out for you? Does it hold the alternator firmly in place without tilting at the top?
srode is offline
post #8 of 11 (permalink) Old Mar 25th, 10, 06:32 PM Thread Starter
Well Summit said they would exchange or refund if I wanted and I called Stewart talked to Mark in Production. He wasn't aware of a problem with earlier models but did some investigating and is going to have a spacer made and ship it to me wanted to know how large outside diameter I needed too. No cost to me, great service! Wanted to know if I needed a longer bolt to but told him I would find one here so not to worry. I let him know that I thought it would be a problem with any GMs prior to Mid 70's using the long pump if they had the same casting to start with. They're going to look into it and I'm guessing may add a spacer with this pump in the future. Very happy camper now, gotta love a company that takes the time to make things right these days!
srode is offline
post #9 of 11 (permalink) Old Mar 26th, 10, 01:20 PM
Yes, the adjustable (Billet Industries) works well, came with a 1" tube spacer to get a straignt shot to their top alt extension from the water pump. Little long arm that connects to alt and adjuster. Act like a leverage device. It holds the alt well, takes very little effort to snug up belt into pulley. Running the 3" factory deep pulley. Drives off crank and water pump. The ps and Vintage AC dual belts run straight off crank.
Here is a couple shot if it.
ID:	14997   Click image for larger version
TC # 349
zdld17 is offline
post #10 of 11 (permalink) Old Mar 27th, 10, 11:57 AM Thread Starter
Stewart shipped my spacers (they made 2) overnight to me - put one on and it works out perfectly. Nice polished aluminum pieces - very impressed! Gotta love that kind of customer service from a company now days.
srode is offline
post #11 of 11 (permalink) Old Mar 27th, 10, 01:12 PM
That's good to hear ! I always thought Stewart was a Top-notch company with a great product !
TJS69 is offline
