Quadrajet 4barrel choke question - Team Camaro Tech
post #1 of 8 (permalink) Old Mar 25th, 10, 06:01 PM Thread Starter
Hello all,
I am wondering if someone can let me know what type of choke is on my 4bbl q-jet...7028212 DH.
I am going to replace my 2 barrel with this 4 barrel q-jet and an Edelbrock Performer RPM Q-Jet Intake (7104), and want to make sure everything will work correctly together.
Thanks a lot for the help!
brewcity is offline
post #2 of 8 (permalink) Old Mar 25th, 10, 07:57 PM
Wes
Re: Quadrajet 4barrel choke question
Your car originally had a divorced choke. Here's the kit:
http://www.rickscamaros.com/product....dept%5Fid=3155
Straight-line-69 is offline
post #3 of 8 (permalink) Old Mar 25th, 10, 08:02 PM Thread Starter
Thanks for the help...so will it work with the Edelbrock Performer RPM?
brewcity is offline
post #4 of 8 (permalink) Old Mar 26th, 10, 12:39 PM
Wes
Indeed. The Performer intake has the choke stove to mount the kit noted above.
post #5 of 8 (permalink) Old Mar 26th, 10, 02:12 PM
You might double check that. I think there is a Performer 2101 that has the choke stove cast in. I'm not aware of a Performer RPM that does, however.
BPOS is offline
post #6 of 8 (permalink) Old Mar 26th, 10, 03:22 PM
Roger
rogerh's Avatar
Copy and past from Edelbrock site.
PPERFORMER RPM (1500-6500 rpm)
Designed for 1955-86 262-400 c.i.d. Chevy V8s for maximum power and a broad torque curve for high-performance street/marine. Provides power like a single-plane and throttle response like a dual-plane. Has provisions to add oil fill tube. No provisions for exhaust heated or stock-style choke. Accepts late-model waterneck, air-conditioning, alternator and H.E.I. Will fit cast iron Chevrolet Bowtie heads, but will not fit 1987 and later cast iron heads. Will not fit under stock Corvette hood. Available with standard finish, polished or EnduraShine finish
rogerh is offline
post #7 of 8 (permalink) Old Mar 26th, 10, 09:38 PM
Wes
We're talking about the Q-Jet Performer and the Q-Jet RPM Performer. Yes, both have the choke stove for the divorced choke.
Here's a photo of the Q-Jet RPM Perfomer:
http://www.jegs.com/i/Edelbrock/350/7104/10002/-1
It's not the best angle, but you can clearly see the stove on the other side of the carb pad and the hole for the screw that would attach the thermostat spring assembly.
post #8 of 8 (permalink) Old Mar 26th, 10, 10:30 PM
Oops my bad - sorry for any confusion. I plumb forgot about the RPM Q-Jet.
BPOS is offline
