PCV oil leak - Team Camaro Tech
post #1 of 8 (permalink) Old Mar 25th, 10, 06:33 PM Thread Starter
Keith
PCV oil leak
I am getting some oil "seepage" out of my PCV valve grommet after some highway driving.
I am assuming that I need a new valve, but my quesitons is, which one should I get...my cam is a solid lifter (I don't know the specs) that only makes about 5 inches of vacuum at idle.
Keith
1967 Camaro
Muncie M-20
GM 8.5, 3.73 posi
keithl1967 is offline
post #2 of 8 (permalink) Old Mar 25th, 10, 07:53 PM
Wes
Re: PCV oil leak
You likely need a new grommet; not valve. If the valve rattles freely, it's good.
Straight-line-69 is offline
post #3 of 8 (permalink) Old Mar 25th, 10, 07:54 PM
DT
Donny
DT's Avatar
Re: PCV oil leak
I thought that was a myth with PCV's???
DT is offline
post #4 of 8 (permalink) Old Mar 25th, 10, 08:26 PM
Skip
Skeeter55's Avatar
Re: PCV oil leak
Are you using any baffles with the PCV.
I NEED TO HIT THE LOTTERY
Skeeter55 is offline
post #5 of 8 (permalink) Old Mar 25th, 10, 08:27 PM
Steiner
Re: PCV oil leak
Purolator CV736V is the one specified for '69 302 and the 375hp 327 Corvette...both low vacuum solid lifter engines. If your valve cover is not baffled, there are baffled grommets over on the wall at Autozone with the dress up parts that will help a little bit with oil splash. You can also use a little disc of steel wool to help separate the oil and air.
If it rattles, it may mean it's good but if it's the wrong part it'll never open.
'69 Camaro
500hp/538lbft
Steiner is offline
post #6 of 8 (permalink) Old Mar 26th, 10, 02:13 AM
Ron
Re: PCV oil leak
GM installs the PCV Valve on the Drivers Valve Cover as opposed to the Psgr Valve Cover because there is less Oil Vapour Density there as opposed to the Psgr Side which tends to be denser due to Windage. An under cover Baffle will help; however, if you have Girdle interference, the Girdle tends to work like a Baffel. If you are still plagued with the problem you may have to use a Dodge Style Above Cover Breather and run the PCV Valve from it. It is also a good idea to run a Dodge Style Breather on the Psgr Side Cover and hose it to the Air Breather Base Plate.
This was my 70 1/2 Z28
Z15CAM is offline
post #7 of 8 (permalink) Old Mar 26th, 10, 07:46 AM
Howard
Re: PCV oil leak
If you are talking about oil seeping between the rubber grommet and valve cover, I used "The Right Stuff" sealer by wiping some around the groove of the grommet before pushing it in place on the cover.Most autoparts stores sell it.It's a little pricey but well worth it.Let it dry overnight before installing the pcv valve.Be sure to clean all surfaces with some alcohol first to make a good bond.The sealer is by far the best I have ever used.
Just Having fun with all My Big Block Toys!!!
bbmusclecars427 is offline
post #8 of 8 (permalink) Old Mar 29th, 10, 05:27 AM Thread Starter
Keith
Re: PCV oil leak
I have no baflle, but do have a stud girdle...I will try the new grommet w/ th ebaffle for autozone to see if that helps. I am running a breather cap on the pass side (PCV is on the driver side), but do not have it hosed to the air filter housing...
Keith
1967 Camaro
Muncie M-20
GM 8.5, 3.73 posi
