Real Rochester Q-jet or a Summit version? - Team Camaro Tech
post #1 of 13 (permalink) Old Mar 25th, 10, 08:54 PM Thread Starter
OK...I do have another question regarding the carb...sorry for all the questions.
What do you guys recommend...getting a real manufactured q-jet, or getting a summit rebuilt one like this: http://www.summitracing.com/parts/SUM-210210/?rtype=1
Are the summit ones real rebuilt rochester q-jets, or just their rendition of one? Will the above one work with an automatic? I need a 7028212 DH rochester q-jet model due to having a powerglide.
Can the summit ones be tuned as well as the original q-jet's?
Thanks for ALL the help! I do appreciate it.
brewcity is offline
post #2 of 13 (permalink) Old Mar 25th, 10, 10:58 PM
Ed
Re: Real rochester q-jet or a summit version?
It's a real Q Jet, regardless of who rebuilt it, so tuning and parts will be the same.
I don't know of any QJ's that were manual tranny specific, but I'm sure there could be one. Anyway it will work with a powerglide, T350 or T400 with little to no mods, and a 700r4 w/ an inexpensive bracket update. Yes, it will work with an automatic.
Where are you at in Milwaukee, as a qjet fan myself I may be able to help you
freezined is offline
post #3 of 13 (permalink) Old Mar 25th, 10, 11:55 PM
Steiner
If you're set on a Quadrajet, National Carburetor sells them for about $100 less than Summit and has a lifetime warranty. You can give them a call to see what they say about your specific application. My dad's '85 F150 uses a funky electronic feedback carb and they did a good job with the one I bought for him.
http://www.nationalcarburetors.com/l...partnum=nd4213
'69 Camaro
500hp/538lbft
Steiner is offline
post #4 of 13 (permalink) Old Mar 26th, 10, 05:22 AM
Guess
HwyStarJoe's Avatar
Re: Real rochester Q-jet or a Summit version?
Hey Steiner.... any idea about turn-around time for that place?
HwyStarJoe is offline
post #5 of 13 (permalink) Old Mar 26th, 10, 05:45 AM
Steiner
On rebuilds? No idea. I know when dad's came in it was missing something that needed to be done for a sensor. They immediately sent him a UPS pick up, did the work, and had it back to him the same week.
Here's their rebuild site:
http://www.antiquecarburetors.com/
'69 Camaro
500hp/538lbft
Steiner is offline
post #6 of 13 (permalink) Old Mar 26th, 10, 09:53 AM
Be advised, the replacement carbs that summit (or anybody) sells these days are later model carbs than would have been on you car originally. That means they will have electric chokes and are somewhat more "adjustable" with the adjustable part throttle screw that originals don't have.
But later model carbs came from cars that used throttle cables instead of hard linkage. You will have to mod the Qjet to accept your linkage and your kickdown linkage for the powerglide. It's all doable but good to know this in advance.
This is what I had to do when I got a replacement QJet from JET.
Melrose RS is offline
post #7 of 13 (permalink) Old Mar 26th, 10, 10:16 AM Thread Starter
Thanks a lot for the help! I am west of Milwaukee about 15 minutes.
brewcity is offline
post #8 of 13 (permalink) Old Mar 26th, 10, 10:17 AM Thread Starter
OK...thanks for the tip...So this Summit version would work just fine with a choke kit for my edelbrock preformer RPM?
brewcity is offline
post #9 of 13 (permalink) Old Mar 26th, 10, 10:20 AM
It will have it's own choke coil. You just run a switched 12V line to it from the fuse box. Doesn't matter what intake as long as it's a spreadbore like the QJet.
post #10 of 13 (permalink) Old Mar 26th, 10, 10:50 AM Thread Starter
So it will no longer be a divorced choke, I am modifying it to an electric?
brewcity is offline
post #11 of 13 (permalink) Old Mar 26th, 10, 12:43 PM
NO, having just looked at the picture of the carb you linked,
it specifies "divorced choke" so that is what it would be and you wouldn't have to modify anything.
Sorry I didn't look at the specific link before. If your Eddy intake has a place to mount the divorced choke coil, you'll be all set.
post #12 of 13 (permalink) Old Mar 26th, 10, 12:57 PM Thread Starter
OK...thats what I thought, and yes, the Edelbrock intake does have a spot for the choke coil. They actually have a choke kit for the specific performer RPM that I'm looking at...I just wanted to make sure i had the right set-up!
Thanks a lot for all the help!
brewcity is offline
post #13 of 13 (permalink) Old Mar 26th, 10, 01:29 PM
Vintage 68's Avatar
Wink Re: Real rochester Q-jet or a Summit version?
There actually is a difference in Manual vs. Auto Q-Jets
Not only do the Auto carb.s have a different throttle hook-up bracket with provision for the kick-down linkage, their internal jetting, calibration Rods and Secondary Valve parts and settings are slightly differrent.
It's not a big deal to make one or the other work on any set-up, just may have to add a kick-down linkage stud or readjust the jetting/rods or air-valve while tuning for your needs.
Also, if you're looking for a unit that you can bolt-on and it will work right out of the box - contact Sean Murphy
At - http://www.smicarburetor.com/
He does excellent work and I've never had problem one with one of his carbs!
1968 Convertible
Some trucks
Vintage 68 is offline
