Best sealing header gaskets ? - Team Camaro Tech
post #1 of 13 (permalink) Old Mar 28th, 10, 06:49 AM Thread Starter
Chris
I have had trouble with my hooker super comp header leaking on the left bank. My engine is a stock iron head 1969 302. I am putting it back together after a cam change and wonder what is the best header gasket to use to cure this problem ?
Thanks again,
Chris
Chris Clark is offline
post #2 of 13 (permalink) Old Mar 28th, 10, 07:00 AM
Tony
Re: Best sealing header gaskets ?
Chris; I'm looking for some of the same advice. I'm currently assembling a '69 302 and will probably be using my Hooker headers as well. What are you running for an exhaust behind the headers? I have a stainless chambered exhaust that I was running with stock manifolds on my 350 - wonder how headers will sounds with that same system. Thanks.
Tony's '69 -
69RS/Z28 is offline
post #3 of 13 (permalink) Old Mar 28th, 10, 07:09 AM Thread Starter
Chris
I am using a stock non chambered system. Yours should sound great with headers hooked to the chambered system and the performance will be much better! Let me know what you find out.
Thanks,
Chris
post #4 of 13 (permalink) Old Mar 28th, 10, 07:16 AM
Nick
Rarerat's Avatar
My old Blue 69 was always going through header gaskets until I switched to a set of Percys Aluminum gaskets. I never had to change them again after that.
Good luck
http://www.summitracing.com/parts/PHP-66011/
Rarerat is offline
post #5 of 13 (permalink) Old Mar 28th, 10, 10:04 AM
prostreet69camaro's Avatar
I use the Felrpo header gaskets between the header and head. Then use the SS bolts that have the allen screw in the middle of the head. You tighten the bolts then tighten the allen screw. The bolts will not loosen up and you should have no leaks. I had these on my small block for 10 years with no leaks and my big block now for 5 years with no leaks. This was both on aluminum heads.
Either that or the exhaust is loud and I cant hear the leak. Well my wife says I am hard of hearing anyway.
prostreet69camaro is offline
post #6 of 13 (permalink) Old Mar 28th, 10, 11:17 AM
"Tri-Tip"
Gary L's Avatar
I use the Felpro metal/paper gasket that comes in their V8 rebuild gasket set. You can buy them separate. They look good without the extra material between ports and seal perfect with my Thorleys. No need to buy something expensive
Gary L is offline
post #7 of 13 (permalink) Old Mar 28th, 10, 03:39 PM
scblucam's Avatar
Mr. Gasket has worked for me. Only one change since 1988
68 302 M20 - 85 IROC Z
scblucam is offline
post #8 of 13 (permalink) Old Mar 28th, 10, 04:19 PM
Keith
I bought a pair of Remflex right before winter--I will be installing them in the next couple of week sor so, but have heard great things about them, depsite their high price tag...
Keith
1967 Camaro
Muncie M-20
GM 8.5, 3.73 posi
keithl1967 is offline
post #9 of 13 (permalink) Old Mar 28th, 10, 04:26 PM
Mike Montgomery
Remflex are the best
http://www.remflex.com/
michael montgomery<BR>69 SS 396/350
michaelm5 is offline
post #10 of 13 (permalink) Old Mar 28th, 10, 05:00 PM
Dave C
Good luck
X-2 no troubles here either.I also use the perseys header bolts which are great to...
PRO.ST69orange
post #11 of 13 (permalink) Old Mar 28th, 10, 05:25 PM
Chris
COMETIC! They don't leak.
hirpms is offline
post #12 of 13 (permalink) Old Mar 28th, 10, 10:56 PM
AJ
Stock Exhaust manifold gaskets work best for me, hands down.
The blue-ish fel-pro header gaskets suck.
'68 333" Camaro
'14 5.0 Mustang
ace's68 is offline
post #13 of 13 (permalink) Old Mar 29th, 10, 08:35 AM
"Tri-Tip"
Gary L's Avatar
Gary L is offline
