Fan for 408 build - Team Camaro Tech
post #1 of 8 (permalink) Old Mar 28th, 10, 07:01 AM Thread Starter
Fan for 408 build
Finishing up my build and thinking about replacing my fan - motor won't run over 6500 ever, should stop pulling at 5500-6000 rpm - I have a flex fan now but thinking of putting on a clutch fan - flex-a-lite makes quite a few options for fans - what do you guys recommend / think?
69 Pace Car and 69 Hard top
srode is offline
post #2 of 8 (permalink) Old Mar 28th, 10, 07:28 AM
Re: Fan for 408 build
I had my stock GM fan to 7000 a few times... went electric this year
So far idling for 30 minutes or so,never went over 120* with aluminum 21" 3 core and electric fan...on the street...???? find out soon.
68 Camaro~LSx ~all motor
post #3 of 8 (permalink) Old Mar 28th, 10, 08:25 AM Thread Starter
Doug, do you have a fan clutch on your fan? If so is it thermal?
srode is offline
post #4 of 8 (permalink) Old Mar 28th, 10, 09:08 AM
No... it was direct drive. Clutch went out years ago and I did away with.
post #5 of 8 (permalink) Old Mar 28th, 10, 02:37 PM
Steiner
I've got the Flex-a-Lite 5718 (six blade 18") and Hayden 2705 standard thermal clutch. Works fine for me on a 355. I'll be using it on the new 400 in a few weeks. The combo replaced a mechanical fan I was running.
'69 Camaro
500hp/538lbft
Steiner is offline
post #6 of 8 (permalink) Old Mar 28th, 10, 05:47 PM Thread Starter
Curious why you chose the Hayden clutch instead of the Felx-a-lite clutch? I see the price is less for the Hayden, any other reason?
srode is offline
post #7 of 8 (permalink) Old Mar 29th, 10, 10:09 AM
Steiner
I'd just heard from a few different places that Hayden made a good clutch. No first hand knowledge though. They fit together correctly fine though.
'69 Camaro
500hp/538lbft
Steiner is offline
post #8 of 8 (permalink) Old Mar 29th, 10, 07:36 PM Thread Starter
I ordered that set up from Summit this morning - should be here Wednesday - but won't put it on until it's done with the dyno run in and a couple pulls which is hopefully late this week.
srode is offline
