DZ 302 Engine Crank Bearing Cap Part #s - Team Camaro Tech
post #1 of 6 (permalink) Old Mar 28th, 10, 12:46 PM Thread Starter
Are the bearing caps for the front and rear crank bearing journals different part #'S than the middle three 2482 four bolt caps? I thought they were all the nodular iron spec and that is indicated by the 2482 part #. Does a front bearing cap with a part #3951? make sense. And what should they be if not the 2482? Thanks.
clm69z28 is offline
post #2 of 6 (permalink) Old Mar 28th, 10, 01:52 PM
Re: DZ 302 Engine Crank Bearing Cap Part #s
There might be a number as to position from the front cast into the cap.
post #3 of 6 (permalink) Old Mar 28th, 10, 02:12 PM
Nos. 1 & 5, have to be diffrent part nos, they only have 2 bolts, and one has an oil pump.
john68 is offline
post #4 of 6 (permalink) Old Mar 28th, 10, 09:58 PM Thread Starter
John68:
That's right and so I am trying to figure out what that part # should be. Any help would be appreciated.
clm69z28 is offline
post #5 of 6 (permalink) Old Mar 28th, 10, 10:10 PM
probably the same part number as every 350 made from 69 until the mid 70's that used the same block. i could go out to the garage and look at the 4 bolt mid 70's 350 block i've got.
you don't plan sincerity.
novaderrik is offline
post #6 of 6 (permalink) Old Mar 29th, 10, 08:43 PM Thread Starter
Novaderrik;
If it was easy I sure would appreciate it.
clm69z28 is offline
