Dale
67 Camaro, Bolting 327 to Powerglide. Why only 3 Washers.
I have not been on for a while, but still been working on the car. Engine is in, trans will be installed in the next hour. Have a dumb question that maybe someone has already had experience with.I ordered from AMK new bolt kit for the connection of the 327 motor to the Powerglide. They are all the correct size, I am not sure about the markings but did not really care at this location. The part number is G-4787 and has 9 items in it:4 - Short Bolts2 - Longer Bolts (these go on the lowest spot on each side)1 - Flat Washer2 - Lock WashersUnless someone pipes back real fast, I am probably not going to put these washers in the correct location. But, here is my questions:WHY ONLY 3 WASHERS FOR 6 BOLTS??AMK usually does the correct thing and I am having NO thoughts on this concept. Not a big deal, but many of you have seen me help people (and i have been helped) on some of these little dumb things in the past.If you know, let me know!!Thanks!Dale
67 R/S Coupe, Sierra Fawn
