Pilot Bearing Removal - Team Camaro Tech
post #1 of 18 (permalink) Old Mar 28th, 10, 07:16 PM Thread Starter
Installed a pilot bearing with needle bearings etc. instead of a solid metal type. I was told it was a better bearing and maybe so. However, while changing my flywheel I noticed my pilot bearing was damaged. Must have happened while installing ther 4 speed trans.
What is the best way to pull the bearing and should I go back to the solid type? The needle type seems too delicate??
Appreciate any experience someone has with this.
Countryside_Cafe is offline
post #2 of 18 (permalink) Old Mar 28th, 10, 07:20 PM
Skip
Skeeter55's Avatar
Re: Pilot Bearing Removal
They make a nice grease fitting that you screw in to the old bearing then attach a grease gun to it and pump it out... Yes you can use a bronze bushing rather then a needle bearing.
I NEED TO HIT THE LOTTERY
Skeeter55 is offline
post #3 of 18 (permalink) Old Mar 28th, 10, 07:29 PM
Ron
For Bronze Pilot Bearing I just Screw in a Bolt with threads slightly larger then the Pilot Hole Diameter and use a small Crow Bar to pop it out, I can't say if this method will work for the Needle Bearing Design. Over all I have greater confidence using Bronze Pilot Bearings.
PS: If I recall I used a bolt with long threads that grab the inner lining of the Pilot Bearing and continue to thread the bolt until it butts against the Crank Shaft; continue turning the bolt and the Pilot Bearing just works it's way out ;o)
This was my 70 1/2 Z28
Z15CAM is offline
post #4 of 18 (permalink) Old Mar 28th, 10, 07:35 PM Thread Starter
How does the grease fitting tool thread into the bearing and where can you buy it?
Please reply - thanks
post #5 of 18 (permalink) Old Mar 28th, 10, 07:36 PM
Skip
Skeeter55's Avatar
Ill try to look for it.
post #6 of 18 (permalink) Old Mar 28th, 10, 07:38 PM Thread Starter
Thanks, I will try also. Not sure how it threads into the bearing but must be fairly tight to work.
post #7 of 18 (permalink) Old Mar 28th, 10, 07:41 PM
Skip
Skeeter55's Avatar
I found this looks very easy to do... Still have to look for that tool
post #8 of 18 (permalink) Old Mar 28th, 10, 10:27 PM
john
wagonman's Avatar
If you ask me the needle bearing design is over engineered.It is a dirty envorinment for a needle bearing.
A simple bronze type has worked well for decades.
Remember,I'm not making this stuff up!
1969 rs/ss 396 350hp/4spd conv a/c,pw,ps,foldown
1968 Z/28 crossram- j/l8 conv pw,ps,foldown
1963 nova ss 350/4spd conv a/c,ps,pt
1963 nova 400 4dr 6cyl/700r4 a/c
2006 GT/5spd mustang conv
wagonman is offline
post #9 of 18 (permalink) Old Mar 29th, 10, 08:15 AM
Stay away from the China type bronze bearings, too much iron. Use GM or Federa Mogul
Do the magnet test. If it sticks , dont use it.
TC # 349
zdld17 is offline
post #10 of 18 (permalink) Old Mar 29th, 10, 10:30 AM
I've removed my pilot bearing using wet toilet paper and a wooden dowl. I just kept jamming toilet paper into the hole, pounding it in with the dowl, until the bearing popped out. Pull out the leftover toilet paper and blow out with air to dry.
ColoradoZ28
ColoradoZ28 is offline
post #11 of 18 (permalink) Old Mar 29th, 10, 11:10 AM
Andrew
Andrew69's Avatar
I rented a little bearing removal tool from my local auto parts store. It reached in and grabbed the bearing from the back, then I turned the screw and the bearing slid out.
Skunk Works
Some photos:
Member # 159
Andrew69 is offline
post #12 of 18 (permalink) Old Mar 29th, 10, 11:33 AM
ColoradoZ28
Same as just packing the hole with a grease gun , grease zerk fitting fits the hole perfect.
TC # 349
zdld17 is offline
post #13 of 18 (permalink) Old Mar 29th, 10, 11:41 AM
Bill
Calpantera's Avatar
Never heard of the wet toilet paper method, sounds cleaner than the grease method which I have used in the past. Also I agree on the bearing type. I prefer the bronze.
Calpantera is offline
post #14 of 18 (permalink) Old Mar 29th, 10, 11:50 AM
Marc
I tried the grease method and unless the bearing is still perfectly round, it just makes a greasy mess. I too rented the bearing removal tool from Autozone and popped it right out. No fuss, no muss.
SS69Cam is offline
post #15 of 18 (permalink) Old Mar 29th, 10, 12:43 PM
Bill
Calpantera's Avatar
The nice thing about the loaner tools from autozone is that they do not cost anything to rent, you just leave a deposit. I frequesnt AZ so much that returning the tool is usually just on my next trip there. I think you can have it for 30 days, just don't forget to return it. I now "own" a oil pump priming tool
