(Help) a non Camaro question? - Team Camaro Tech
post #1 of 4 (permalink) Old Mar 28th, 10, 07:50 PM Thread Starter
Tony
Send a message via AIM to tony -Di
I have a 1999 chevy S10 pickup with 119000.miles on her for a while now i would hear ticking noise i thought is might be an exh leak when i spepeed on the gas when driving a mounth ar so ago on a cold morning when i started it was clacking loud and running rough with slight popping comming from exh, after a minute it quited down . i shut off the engine I was down over a qt of oil i added oil went to work i found that the remote oil filter hose was leaking i changed it. but ever since it starts the lifters sound loud they quite down but when i am driving and step on the gas i can hear them what do you think?
Tony
tony -Di is offline
post #2 of 4 (permalink) Old Mar 28th, 10, 09:20 PM
kt
kelly
Re: (help) a non camaro question?
Valves hangin up...is the check engine lamp on???..very common in these parts, see at least one a month or so at the dealer..starts out as a misfire after a long hill is pulled, a set of reman heads and the issue is gone.
kt is offline
post #3 of 4 (permalink) Old Mar 29th, 10, 04:46 PM Thread Starter
Tony
the ck engine is not on and hasnt gone on
tony -Di is offline
post #4 of 4 (permalink) Old Apr 2nd, 10, 06:35 PM Thread Starter
Tony
Re: (Help) a non Camaro question?
is there any treatment to ad to the oil ??and if the valves are sticking it quites down after afew and under a load is louder its not the lifters ?
tony -Di is offline
