Timing - Team Camaro Tech
post #1 of 4 (permalink) Old Mar 29th, 10, 04:46 PM Thread Starter
gary
Timing
hi all i just installed the 1181 pertronixs ignition and flame thrower coil in my stock 1967 327 2bbl engine all went well checked timing and at 33* is this good, the motor idles great and in drive but havent drove it for a test drive after, because its raining is this good for my 327 for timing. what is the timing suppost to be for a stock 67 327 2bbl engine thanks gary
Real canadian67 is offline
post #2 of 4 (permalink) Old Mar 29th, 10, 06:26 PM
Re: timing
Is the 33 with the vacuum advance hooked up to manifold vacuum?
If not it is way to high. I suppose somewhere between 8 and 12 degrees would be in the right range without the vacuum advance.
1969 Nova SS, all motor BBC with C Straub girly cam, AutoGear M23W, 4:10
jmartorana is offline
post #3 of 4 (permalink) Old Mar 30th, 10, 12:20 AM
Steps
Re: timing
Intial 8 degs VA disconnected
Steptoe is offline
post #4 of 4 (permalink) Old Mar 30th, 10, 02:10 AM Thread Starter
gary
Re: timing
yes vac hooked up.
