Camaro owner... but a ford question - Team Camaro Tech
post #1 of 8 (permalink) Old Mar 29th, 10, 05:00 PM Thread Starter
jeff morrison
Don't get mad, but this about my Ford E-150 van. Started to work today and got just down the road and saw oil light flash and oil pressure down to zero!! Dang!! So, I pulled into parking lot and shut it off. started it back up and pressure was fine, let idle for a minute and it went down again. So, it is ok when you first start it then it goes up and down after a minute.
Limped it back home, pulling over about 8 times to start it back up to make sure oil was still getting in engine. Changed oil and filter to see in case filter was clogged. seemed to help some but still goes up and down.
Any ideas ? Oil pump go out? Screen filter clogged?
I'll make sure next question is on Camaro.
layne02 is offline
post #2 of 8 (permalink) Old Mar 29th, 10, 05:39 PM
Keith
Re: Camaro owner... but a ford question
Problem is...It'd a FORD LOL
Now that that's out of the way, what's he oil level when off and cool?
If oill level is OK, could be that the pump pickup came off of the pump...make sit pump oil when the level is high enough to be sucked in without the pickup tube, but once the initial pumpin is done, cannot "grab" any more oil...
Keith
1967 Camaro
Muncie M-20
GM 8.5, 3.73 posi
keithl1967 is offline
post #3 of 8 (permalink) Old Mar 29th, 10, 05:59 PM Thread Starter
jeff morrison
Keith, you seem to be answering all of my dumb questions tonight. Ever had one of those weeks when everything tears up? I have.
Now, if the oil pickup is off, I assume I will have to remove pan. Just wondering if it will come off without raising motor some.
layne02 is offline
post #4 of 8 (permalink) Old Mar 29th, 10, 06:16 PM
DONNIE
Oil psi switch probley bad or did it knock when the psi went down ,if it didn't put a new psi swich in the try it again unless you have a oil psi tester change a bunch of these psi switches, OH AND THE FORD PICKUP SCREENS BOLT DOWN SO THEY CANT FALL OUT IF ITS A 302 OR 351 OR IS IS A NEWER VAN WITH THE 5.4 OR 4.6
"Well, the trouble with our liberal friends is not that they are ignorant, but that they know so much that isn't so." -- Ronald Reagan
67CAMAROSS is offline
post #5 of 8 (permalink) Old Mar 29th, 10, 06:16 PM
ZZ_430's Avatar
Jeff, I've seen that happen when the oil pump shaft starts to spin in the distributor drive gear.
The hex starts to round off and some times it slips and then catches. The easy thing to do is pull the distributor and check the shaft/drive gear for wear.
Did the engine make any noises that sounded like low pressure? You could try an oil pressure switch.
(Edit: I just saw the post above mine.)
Don ~ TC Member #15 ~
Don't mess with Texas!
ZZ_430 is offline
post #6 of 8 (permalink) Old Mar 29th, 10, 06:47 PM
Bill
Jeff,
One other thing to check is the oil drainbacks in the corners of the heads. Ford uses 4 pretty small holes to drain the oil back to the pan and if they get sludged up the valve covers fill up with oil and you start losing pressure.
This only pertains to the traditional small blocks by the way, not the newer modular engines.
Bill Koustenis
Owner
Advanced Automotive Machine
Waldorf Md
BillK is offline
post #7 of 8 (permalink) Old Mar 29th, 10, 06:51 PM Thread Starter
jeff morrison
Thanks for these Ford answers as bad as it hurts to do it. I forgot to mention that it is a 2001. If that helps any
It has the big v-8
layne02 is offline
post #8 of 8 (permalink) Old Mar 29th, 10, 07:01 PM
Andy
Send a message via AIM to 67SS&99SS
I would check the oil pressure sending unit. My dad has a 96 ranger and in the past he had issues with fluctuating oil pressure. The sending unit was the culprit. I think it was about 8 bucks. Check the simple cheap stuff first.
1967 Camaro SS: 406 sbc, 522hp/514 ft lbs, Doug's 1 3/4" headers, M20, posi, 3.73's, vintage air gen IV, IROC steering box, Comp Eng. weld-in sfc's & traction bars, chrome US Mags
67SS&99SS is offline
