Car is smoking from tail pipe - Team Camaro Tech
post #1 of 9 (permalink) Old Mar 29th, 10, 07:18 PM Thread Starter
knightmoose's Avatar
67 with 383 is smoking from both back tail pipes, the car does have a "transmission leak" as there is a puddle in the garage, its hard for me to distinguish the color of the smaoke its like white clear smoke versus blue or black, the car isnt running sluggish and it isnt over heating or anything, the smell doesnt smell like gas either the smolking just strated this weekend could the fuel i have gotten simply have been bad or had condensation in it or something?
To rule out head gasket, i removed the radiator cap no bubbles and the car radiator is full to the top even after driving it for a good 1hr straight and the over flow tank still has fluid in it im not sure why its smoking outthe back tail pipes? With the transmission leak could there be a way its buring it off? . Doesnt really have that sweet anti freeze smell or water smell ? Although its kind of white the smoke is clear as well and its smoking equally from both dual back tail pipes?.
If not a blown head gasket maybe an intake manifold gasket i just dont know, what tests would you do to strat rulling out possible things?
it about helping others
knightmoose is offline
post #2 of 9 (permalink) Old Mar 29th, 10, 08:27 PM
steve
Re: car is smoking from tail pipe
If it is an automatic transmission it could be a bad modulator.The vaccum from the engine can draw oil from the transmission into the intake if the modulator is bad. Pull the vaccum line off and see if there's oil in it.
grampstoyz is offline
post #3 of 9 (permalink) Old Mar 29th, 10, 11:34 PM Thread Starter
hmm i started agin after it has been sitting now there is less smoke and when it hits the ground the ground is wet as though there is condensation in the tail pipes? hmm what ever the problem is it is not NORMAL i will hold blue print engines to their warranty and find out what it is, the engine has aluminum heads what i see is more like a mist is the best way to describe it, that could mean cracked head or something.
if so it has to be at the very very infancy stage of it as im not losing any water anywhere the car isnt over heating in fact it takes time just to getthe engine hot, right now the mist is very small coming from the tail piep its hitting the ground wet and leaving wet spots on both sides of the dual exhaust i think id have to get her really running again before seeingthe mist cloud i saw earlier today as now she has been sitting for 3 hrs and isnt doing it like she was before
post #4 of 9 (permalink) Old Mar 30th, 10, 12:08 AM
AJ
It's very unlikely you have TWO cracked heads leaking water into the cylinders, if you did and the leak was some what bad, you would know instantly, the motor would hydro lock every few starts, and water would be blown out of the spark plug holes when removed.
I know even in mild weather I get condensation out the pipes (mid 70*) especially if the car is cold condensation will happen from the heat going into the cool pipes.
Water/coolant can't just run out the pipes and hit the ground.
'68 333" Camaro
'14 5.0 Mustang
ace's68 is offline
post #5 of 9 (permalink) Old Mar 30th, 10, 04:37 AM
Dan Ensign
Hot exhaust and cool dry air causes condensation, this is normal, relax, there is nothing wrong. Go drive it and enjoy.
Dan E.
69 SS396 4spd. 4.10 posi. x66 coupe
Dan E. is offline
post #6 of 9 (permalink) Old Mar 30th, 10, 07:35 PM Thread Starter
Re: Car is smoking from tail pipe
can a vacumn line connected to the wrong inlet port on the front of the carb cause the problem? i moved 1 hose to a non suction port and the smoking is way subsided
post #7 of 9 (permalink) Old Mar 30th, 10, 07:39 PM
AJ
What vacuum line?
From the distributor to the carb?
And no, it's not likely a vacuum issue is causing this...
'68 333" Camaro
'14 5.0 Mustang
ace's68 is offline
post #8 of 9 (permalink) Old Mar 30th, 10, 07:41 PM Thread Starter
yes the line that goes to the vacumn advance i moved it over and the smoke has subsided smokes a little or when you rev the engine hard, that port has been plugged since the engine was installed and i remembered i unplugged it and plugged the line to it over the weekend because it did raise the idle some than i moved it back thinking like you said what difrence would it make maybe it makes the car run lean or rich or something?
"I pulled some plugs and they are black dry powder sooty apperance, dry black powder .."
post #9 of 9 (permalink) Old Mar 31st, 10, 12:32 AM
AJ
One is a ported vacuum source which has no vacuum at idle, and the other is full manifold which has suction at idle.
You should use the full manifold vacuum.
By moving the line over you changed your timing and changed the idle since the timing was reduced or brought back up depending on which port you moved it to.
Pull both lines, raise rpm's back up to idle, put a timing light on the motor and see what it is doing, then plug the line into the full manifold port and adjust total timing accordingly.
'68 333" Camaro
'14 5.0 Mustang
ace's68 is offline
