70 350 lt1 engine - Team Camaro Tech
post #1 of 5 (permalink) Old Mar 31st, 10, 06:04 AM Thread Starter
70 350 lt1 engine
when motor heats up to 160-170 degrees the motor wants to back fire threw right side exhaust only when the motor is heated!
chevyshowman is offline
post #2 of 5 (permalink) Old Mar 31st, 10, 06:34 AM
Re: 70 350 lt1 engine
Could be the idle mixture screws alittle lean.
post #3 of 5 (permalink) Old Mar 31st, 10, 06:07 PM
greg
Pull your plugs on that side and look at them!
docwilcar is offline
post #4 of 5 (permalink) Old Apr 1st, 10, 11:12 AM
Ron
Possible HOLE in Right side Header Collector which super heats the Exhaust Gases and Ignites them. Does this happen primarily when you let up on the throttle?
This was my 70 1/2 Z28
Z15CAM is offline
post #5 of 5 (permalink) Old Apr 1st, 10, 11:29 AM
foreverlookin's Avatar
Check your valve adjustment
foreverlookin is offline
