Forgot to install manifold restrictor plate for CA car - Team Camaro Tech
post #1 of 6 (permalink) Old Mar 31st, 10, 07:59 PM Thread Starter
Just got done building a 350 and found that I forgot to install the intake manifold gasket restrictor insert, The car is in CA. Do you think its worth pulling the manifold and installing it? How much power do you think I'll really loose for a warmed up carb? Thanks
1967 coupe
bautino95 is offline
post #2 of 6 (permalink) Old Mar 31st, 10, 11:09 PM
Rick
Re: forgot to install manifold restrictor plate for CA car
it is in a 1967 camaro? What yr is the block?
you should be fine...just built a 383 and put it my 68 and got it liscensed no problems.
Rick
68 project...reassembly starting: (383, AFR 195, Air Gap, Comp Cam XR276HR, 1.6 CC Gold rollers, Holley 750, 4/09) (TKO 600 conversion from T350 4/09) (floor pan restored 6/09). (12 bolt 3.73, Wilwood disc, Hotchkis TVS 7/09), Dougs 368 with Big Dog mufflers (9/09), 383 fired up 9/30/09, Candy Apple Red 2012 with white RallyBee stripe
dukemd66 is offline
post #3 of 6 (permalink) Old Apr 1st, 10, 06:32 AM
Send a message via AIM to Satatic
You are not exempt after 25 years old?
Satatic is offline
post #4 of 6 (permalink) Old Apr 1st, 10, 04:57 PM
it's not worth worrying about- i've always left them out. the hotter manifold helps the fuel to stay better atomized for better gas mileage and driveability.
you don't plan sincerity.
novaderrik is offline
post #5 of 6 (permalink) Old Apr 1st, 10, 05:48 PM
Vall
Might get some vapor lock on really hot days, but I wouldn't pull the intake now. Wait and see how it does.
1971BB427 is offline
post #6 of 6 (permalink) Old Apr 1st, 10, 08:11 PM Thread Starter
Re: Forgot to install manifold restrictor plate for CA car
Thanks for the reply's. Yes the car is smog exempt. I was more worried about the performance aspect of things. But I'll just leave it as is for now. Thanks again.
1967 coupe
