Should I install Roller Rockers - Team Camaro Tech
post #1 of 3 (permalink) Old Apr 1st, 10, 04:49 PM Thread Starter
Filip
Just need some thoughts and opinions, I am sure they will be many and varied.
I have a 350 290hp crate engine and have just got the Edelbrock Power Package which includes Alloy Performance Heads, Air gap intake etc.
Is it worth at this stage to install Roller Rockers seeing when I change the heads I have to change and install new push rods.
Any recommendations on brand? I don't want to run Tall covers ( dont know if this makes a difference)
kiwicamaro is offline
post #2 of 3 (permalink) Old Apr 1st, 10, 07:02 PM
Ron
Re: Should I install Roller Rockers
350 290hp
I imagine this is a HFT Engine? Roller Rockers are not required. If it were a 6000+rpm HFT or SFT cammed Engine then I would recommend Roller Rockers like Harland Sharp or Comp Pro Mags on 7'16" Rocker Studs to handle the Lift and Spring Pressure. Lifts approaching .6+" Lift, either Rollers with Girdle or Shaft Roller Rockers.
This was my 70 1/2 Z28
Z15CAM is offline
post #3 of 3 (permalink) Old Apr 2nd, 10, 11:46 AM
Mickey
Moonpie's Avatar
I agree with Ron. If you changed cams then yes it might be worth it.
Moonpie is offline
