Bad ignition switch or faulty starter?? - Team Camaro Tech
post #1 of 4 (permalink) Old Apr 1st, 10, 06:45 PM Thread Starter
kcs
Kevin
Wink Bad ignition switch or faulty starter??
It happened again this year. I started the Camaro up and the starter stayed engaged to the flywheel. I spent about $100.00 having the high torque Powermaster starter rebuilt last year. This time I quickly turned the key back and it stop squealing loudly. My ignition switch is new a few years ago. Went to start the car earlier and starter is wrecked again. Any ideas on this??? Thanks in advance and enjoy your day!!!
kcs
68RS, 404 hp. 350, turbo 350 with 2600 stall, Dougs headers, 3:73 12 bolt
06 Nissan Altima SE-R, Auto, Code Red, All options!!!
kcs is offline
post #2 of 4 (permalink) Old Apr 2nd, 10, 01:36 AM
Re: Bad ignition switch or faulty starter??
it could be that the teeth of the starter drive are engaging too tightly with the ring gear, which causes it to not release properly.
the fix is to add a shim or two between the starter and block.
there is a "proper" way to check it- i think it involves a paper clip stuck between the starter drive teeth and ring gear teeth- but i've always done it by sound.
where in MN are you located?
you don't plan sincerity.
novaderrik is offline
post #3 of 4 (permalink) Old Apr 2nd, 10, 04:23 AM
Steps
They didnt grease or oil the bendex spring...that must be assembled dry.
Steptoe is offline
post #4 of 4 (permalink) Old Apr 2nd, 10, 12:16 PM Thread Starter
kcs
Kevin
Thanks. After I get the starter rebuilt, I'll try to shim it differently.
I am by Princeton. North of Minneapolis about an hour.
kcs
kcs is offline
