Pop in carbureator coming off idle - Team Camaro Tech
post #1 of 7 (permalink) Old Apr 2nd, 10, 10:18 AM Thread Starter
Does not happen all the time but often enough. Sitting at a light at idle sometimes when I go to accelerate I get a little pop in the carb. Only started happening in the last few weeks.
Carb is was restored two years ago and has always ran great.
Recently installed funtional cowl induction, (had open element prior to)could that have something to do with it? Maybe air/fuel mixture?
1969 Camaro SS
350/300 M20
12 Bolt 3:73 Posi
Myfirst 69SS is offline
post #2 of 7 (permalink) Old Apr 2nd, 10, 11:36 AM
Mickey
Moonpie's Avatar
Re: Pop in carbureator coming off idle
What carb is it?
Moonpie is offline
post #3 of 7 (permalink) Old Apr 2nd, 10, 11:39 AM Thread Starter
Sorry Quardrajet..
1969 Camaro SS
350/300 M20
12 Bolt 3:73 Posi
post #4 of 7 (permalink) Old Apr 2nd, 10, 09:17 PM
AJ
Initial timing, vacuum leak, bad tuning, accelerator pump set up wrong or crapping out.
'68 333" Camaro
'14 5.0 Mustang
ace's68 is offline
post #5 of 7 (permalink) Old Apr 3rd, 10, 08:59 AM
Keith
could be a sticking valve, or in need of valve adjustment--is it a solid lifter cam?
Popping back throught he carb is likely not a carb issue, but it can certainly create one, which often "muddies" the water....becomes a "chicken or the egg type thing"...
Like aces said also, could be timing or a vac leak as well...
Keith
1967 Camaro
Muncie M-20
GM 8.5, 3.73 posi
keithl1967 is offline
post #6 of 7 (permalink) Old Apr 6th, 10, 08:37 AM
Mickey
Moonpie's Avatar
Try tightening up all the top screws. Could be a slight vacuum leak somewhere. With the engine off activate the throttle by hand and see if you are getting a good accelerator pump squirt. Sounds like the acc. pump might not be covering the transition to main jets and getting a lean pop. Not enough ignition advance might cause it.
Moonpie is offline
post #7 of 7 (permalink) Old Apr 6th, 10, 09:00 AM
Wes
A vacuum leak causes lean-out which pops in the exhaust.
Popping through a carb means a spark plug(s) is firing with an intake valve(s) open.
Assuming your timing specs and timing chain are good, I'd first look for something in the ignition; bad wire, cracked cap, etc. There's about 90% chance you'll find something that's causing some crossfiring.
Secondly, I'd look for a possible broken valve spring(s).
Straight-line-69 is offline
