take a look at this plug (502)... - Team Camaro Tech
post #1 of 6 (permalink) Old Apr 3rd, 10, 03:19 PM Thread Starter
I tried using my 3/8 drive on this sq head but a bit to big. I don't have anything else with a sq head - only hex. What can I use on this? Also see the 2 plugs below. The one just to the top left of the filter in first pic. The second pic shows from bottom. Can I put oil presure sender there opposed to the the port over the filter (not even sure if this is oii port)? When using the top port, my sender is going to be super close to my headers. I am using an autometer sender.
Clean 67 - 600hp / 579ft lb, 502
St Petersburg, FL
mccomas is offline
post #2 of 6 (permalink) Old Apr 3rd, 10, 04:40 PM
Re: take a look at this plug (502)...
5/16, All tool trucks have them, or take an old 3/8 ext, grind to fit.
john68 is offline
post #3 of 6 (permalink) Old Apr 3rd, 10, 04:42 PM
Steiner
I had a transplanted LT1 engine in an old K5 that had plugs like that. I had to use a 3/8" to 5/16" adapter and that worked. I had to order it. If I can find it, you can have it since I haven't used it since I got rid of that Blazer.
'69 Camaro
500hp/538lbft
Steiner is offline
post #4 of 6 (permalink) Old Apr 3rd, 10, 05:17 PM
ZZ_430's Avatar
Yes, and use a 90* adapter for the sender at the upper port.
Those ports on the bottom are for an oil cooler, I guess you could use one of those, but I've never seen it done.
Don ~ TC Member #15 ~
Don't mess with Texas!
ZZ_430 is offline
post #5 of 6 (permalink) Old Apr 3rd, 10, 05:23 PM
Steiner
Just a heads up....that oil filter looks like it may be a little small in diameter. Myself and some others have pumped oil past the seal on the AC1218 and all over the garage floor. Take a look at this for a better part number:
https://www.camaros.net/forums/showpo...1&postcount=25
'69 Camaro
500hp/538lbft
Steiner is offline
post #6 of 6 (permalink) Old Apr 3rd, 10, 05:45 PM
Snap on make a tool kit especially for these plugs.
TC # 349
zdld17 is offline
