SBC Heads - Team Camaro Tech
post #1 of 9 (permalink) Old Apr 4th, 10, 01:01 AM Thread Starter
SBC Heads
I was given these heads 3986339, Are these heads worth puting money into?
1981Zapper is offline
post #2 of 9 (permalink) Old Apr 4th, 10, 06:48 AM
Re: SBC Heads
These heads are 1971 307/350 with 74 cc chambers.
67 RS 355sbc 11.76et @ 116mph 1.67 60' Deluxe Parchment interior
Bad67355 is offline
post #3 of 9 (permalink) Old Apr 4th, 10, 06:55 AM
Re: SBC Heads
I may be wrong, but I thought 307's had 1.72 intakes and 350's had 1.94or larger intake valves. How could these heads be used on both engines?
In either case, sounds like not worth putting the money into. I'm seeing double hump heads for sale in good shape around $300.
Melrose RS is offline
post #4 of 9 (permalink) Old Apr 4th, 10, 09:35 AM
Re: SBC Heads
http://www.chevytech.com/3c3986339.html
they are either 69 or 75cc depending on year, 1.72/1.50 valves.... not really that great from the looks of it. If you have access to camel humps for cheap I would maybe go for that. Although that is what I am doing, and the machining etc is costing a touch more than I had anticipated due to some upgrades I didn't plan!
brownnote is offline
post #5 of 9 (permalink) Old Apr 4th, 10, 10:55 AM
Smile Re: SBC Heads
The numbers you gave are casting numbers. The casting may be used for different valve sizes and/or different chamber sizes.
The double hump heads do not breath very well when used with today's cams. It is usually better to look at aftermarket heads than to stick money into heads that will disappoint you.
TJS69 is offline
post #6 of 9 (permalink) Old Apr 5th, 10, 03:37 PM
Daniel
Re: SBC Heads
Dart II iron heads come cheap and will out perform any stock heads, they are a very worthy investment IMO.
sweetblue69 is offline
post #7 of 9 (permalink) Old Apr 5th, 10, 05:38 PM
Re: SBC Heads
Dart S/R (stock replacements)
TC # 349
zdld17 is offline
post #8 of 9 (permalink) Old Apr 5th, 10, 11:26 PM
AJ
Re: SBC Heads
I've seen a set of sportsman 2's untouched go in the 11's with a comp 286H-10 and 10.5:1 comp. Seem like a good set for the cash.
'68 333" Camaro
'14 5.0 Mustang
ace's68 is offline
post #9 of 9 (permalink) Old Apr 6th, 10, 09:13 AM
Re: SBC Heads
There is something wrong with these photos in the link. The chamber on the left shows 1.94 sized intake valve seats but 1.94's are not mentioned in the data. Look at the distance between the valve seats. Either the photo is wrong or the data is.
