Headers for 350 - Team Camaro Tech
post #1 of 7 (permalink) Old Apr 4th, 10, 09:45 AM Thread Starter
J
Headers for 350
I just built a new 383 stroaker with Patriot alluminum heads. I noticed that the spark plug holes were slightly lower than stock heads I would assume this is for perf reason. Anyway when I reattached my old set of headers I'm having a tough time getting the plug wires to clear. Anyone experience this problem and can someone recommend a set of headers that would clear.
Thanks in advance.
jkkrs310 is offline
post #2 of 7 (permalink) Old Apr 5th, 10, 08:04 AM
Keith
Re: Headers for 350
Try header or "shortie" plugs before buying new headers...save you xsome $$$...
Accel makes a decent set of shortie plugs...
Keith
1967 Camaro
Muncie M-20
GM 8.5, 3.73 posi
keithl1967 is offline
post #3 of 7 (permalink) Old Apr 5th, 10, 03:31 PM
Daniel
Re: Headers for 350
I agree with keith, if thats your only fitment issue, shorter plugs might work for you.
sweetblue69 is offline
post #4 of 7 (permalink) Old Apr 5th, 10, 03:34 PM
AJ
Re: Headers for 350
If your set of headers are getting worn and just want a new pair these work great with patriots. No power steering, a/c
http://www.summitracing.com/parts/HED-68278/
'68 333" Camaro
'14 5.0 Mustang
ace's68 is offline
post #5 of 7 (permalink) Old Apr 19th, 10, 02:41 PM Thread Starter
J
Re: Headers for 350
Thanks Keith. I had to pound the header to get it to clear one plug on the drivers side. The shorty plugs will help but does not solve the problem. Is this clearance problem common? I also had to pund the header slightly to clear the steering assy. Do you know of a header that might work?
jkkrs310 is offline
post #6 of 7 (permalink) Old Apr 22nd, 10, 11:27 AM
Patric
Re: Headers for 350
have you finnaly found a pair of headers that worked good
patvac is offline
post #7 of 7 (permalink) Old Apr 23rd, 10, 01:20 PM Thread Starter
J
Re: Headers for 350
not yet....still looking.
jkkrs310 is offline
