Lifting points (bolt holes) for 327 - Team Camaro Tech
post #1 of 6 (permalink) Old Apr 6th, 10, 07:51 AM Thread Starter
Bob
I've searched around and found different locations - from modifed plates on intake manifold (w/out carb installed) - as I have an aluminum intake manifold don't think I'll go there! The top two water pump and two top bell housing bolt holes sounds good but not a lot of room between firewall and bell housing. Also out there are those who use head bolt holes - doesn't this risk twisting heads?
Thanks all for your replies!
reddize is offline
post #2 of 6 (permalink) Old Apr 6th, 10, 07:56 AM
Re: Lifting points (bolt holes) for 327
No the heads won't twist.
You can use a carb plate on an Aluminum intake, Its done everyday.
You can use the accessory holes on the heads that have accessory holes.
You can use the exhaust bolt holes.
The bell housing holes the water pump holes.
71 Camaro 355 NA
11.1650 @ 119.30
1.5028 60'
hhott71 is offline
post #3 of 6 (permalink) Old Apr 6th, 10, 07:57 AM
scott
68basecoupe's Avatar
Just pulled the 327 out of my pj about three weeks ago.Used a lift plate on a edelbrock performer intake,no problems,going back in this weekend the same way.
68basecoupe is offline
post #4 of 6 (permalink) Old Apr 6th, 10, 01:23 PM
jeff
Although not the best way to do it I just pulled a 454 (complete with pulleys, alt, etc. minus carb) using the pass side rear intake bolt hole and 1 drivers side accessory hole at the front of the head. The bolts I used were grade 8 and I had a nice heavy chain though.
Jeff.
jostby is offline
post #5 of 6 (permalink) Old Apr 6th, 10, 07:07 PM
Steiner
Same here. Just pulled an iron headed small block with the M20 trans still attached using a lift plate on the Performer RPM. The new engine and TKO will be going in the same way. My builder delivers their engines with intake lift plates on them.
'69 Camaro
500hp/538lbft
Steiner is offline
post #6 of 6 (permalink) Old Apr 7th, 10, 12:16 PM
Russ
Just a suggestion. I often find that the head accy holes are a bit tight to get to with a chain so I use a piece of 1"x .250" thick flat stock ~4" long with holes ~1/2 in from each end to bolt to the head and then I connect the chain to these. Gives just a little extra clearance.
Russ (RJ)
The Garlic Capital, Gilroy,CA
(sold June 15,2014) 1968 RS convertible that is not quite stock
rj68RS is offline
